Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Check your temperature control (Thermostat) settings. If it is not on high/max cool then set it just less than the maximum.
If it still does not cool then I am afraid the problem is of less cooling gas. You have to ask a technician to check and refill.
The problem is the damper (vent from freezer) is bad or just sticking open, try defrosting it and adjusting the position so that you
reduce the amount of cold air going into the fridge, hopefully it'll
just be stuck in the open position and you well have no further
problems. Always here to help.. Richard.
Coldspot 106. Model
This model refrigerator is a relatively small refrigerator. It is a Freezer on top model, and Sears documents lists this unit at 18.1 cu ft. I hope that answers your question about capacity.
I'm glad I could help. If you need anything else, just let me know.
In reality, when you buy a replacement, you buy by dimensions to fit the space not cubic feet of the old one. Go to Home Depot armed with a tape measure.
Turn it off by removing the wall plug for 10 minutes. This will do a power rest to the control electronics. This is a bottom mounted freezer, so cold air for the fridge is vented upwards by a fan. Make sure it is running and there are no ice blockages. Strangely they call the fan in the fridge an
Refrigerator Evaporator Fan Motor. The part is obsolete anyway.
If it normally says 4 for the fridge, that would be 4 degrees Centigrade, which means the freezer should show minus 18'C. Or 36'F Fridge / 0' F Freezer/
This shows all the parts.
https://www.searspartsdirect.com/model/3tradtge4f-000582/kenmore-79575004401-bottom-mount-refrigerator-parts
Not normally a flapper. There is a trap on the rear outside cabinet just below the level of the freezer. Remove it and soak in hot water and bleach for 20 minutes, then flush all the debris out, shake it dry and reinstall.
Put some Vaseline on the O-Ring to help it slide into place. Make sure it is properly inserted at the beginning.
If the filter is located inside the refrigerator:
Turn off the ice maker.
Push the eject button.
Pull the filter out of the housing.
Push the new filter into the housing until it clicks.
Turn on the ice maker.
Run 2 gallons of water through the water dispenser to purge air and residue.
Kenmore appliance model numbers have a three digit prefix (106 in this case) for the manufacturer. The rest of the model number indicates a lot of the specifics for the refrigerator. The third digit is the second group indicates the capacity. This fridge is a 22 cubic foot model (or slightly smaller).
I hope this helps.
From here on Fixya
https://www.fixya.com/support/t26563238-many_cubic_feet_kenmore_coldspot
