20 Most Recent Asko T712 Electric Dryer Questions & Answers
2answers
I need to repalce the
I took the top and back of my unit apart. Then from the back it is still not the eaisiet of tasks.
9/10/2018 8:01:41 PM • Asko T712... • Answered on Sep 10, 2018
Asko dryer will not stay running
possible temp sensor fault
7/15/2018 2:32:32 AM • Asko T712... • Answered on Jul 15, 2018
0answers
0answers
Alarm F1 stoping dryer type T712, what the reason?
For information, behind front panel are optional hidden sensors and one of them had to be reset.
K,W.
6/15/2012 3:20:20 AM • Asko T712... • Answered on Jun 15, 2012
My asko t721 dryer is
Hello, welcome to FixYa.
Based on your description I`d direct you to first check the hi-temp cut out at the back...if you haven`t already.
It will look like this on the Asko dryers...
If you push this to reset and the unit works, great. I would keep an eye on it though since the hi-limit typically trips for a reason such as a excessive long vent or flex vent being used ( stay away from flex venting ) plugged lint filter, plugged vent ot partially plugged etc.
If it doesn`t run after-wards or it`s not tripped, you`ll need to investigate further...if necessary.
Keep me posted on your progress or what you find and I'll help in whatever manner I can. Good luck.
Regards,
Macmarkus :)
6/2/2011 1:31:51 PM • Asko T712... • Answered on Jun 02, 2011
0answers
Unit only heats up partially after a very long
Did you replace the bias sensor as well?
3/13/2011 7:14:44 PM • Asko T712... • Answered on Mar 13, 2011
Element in the back seems to be heating but not
the belt,motor,idler assemblage, drum glides and rollers are all parts the will effect the rotation of the drum. Here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
12/2/2010 11:42:00 PM • Asko T712... • Answered on Dec 02, 2010
My T712C Butterfly Condensor dryer
Hi
Thanks for using FixYa. To start with check the vent is clean, if still not resolved then it seems that the Thermal fuse that has gone bad. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired. You can test it for continuity between its two pins, no continuity means bad fuse. If this is fine then you'll need to check the thermostat, igniter and coils. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
10/5/2010 8:47:28 AM • Asko T712... • Answered on Oct 05, 2010
2answers
Hours for towels or sheets to dry
a dryer can only handel so much if you over load it it cant tumbel the load inside of it so the warm air wont dry them out,,,also what is it set on??? low or hight heat?? how wet are the sheets when you put them in the dryer??? is the dryer getting a good air flow,, it need to breath in lots of air,,,,and that hot wet air need to get out freely,,,if its even slightle blocked the dryer cant work well,,,how often do you clean out the dust filter in the dryer,,,(this should be cleaned every time you use it) also if the sheets just tiy them selfs into a big knot they wont dry
i hope this was of help to you
6/28/2010 4:50:49 PM • Asko T712... • Answered on Jun 28, 2010
Power on switch itermittent have to repeat
change the power switch
6/28/2010 12:21:55 PM • Asko T712... • Answered on Jun 28, 2010
Where is the heater located
Are you familiar with the location of the heater hi-limit for the Asko dryer ? If so, that is the location of the heater assembly, under that housing at the back panel of the unit.
**Turn off the power or unplug the unit from the wall before performing any service**.
If not, make access to the rear of the unit possible, slide it out or whatever the case may be in your situation. You`ll see the back panel has screws all around the perimeter, but also an alongated round cover with screws around it`s perimeter as well. The heater is enclosed in this housing as is the hi-limit reset-able thermostat ( covered by a round black button like rubber cover ).
**If your dryer isn`t heating, check the hi-limit first by pushing in the middle of it`s black rubber cover before dis-assembling your dryer too far.**
Hope this answer`s your question and help`s move you forward. If so please rate this info accordingly.
Thank`s for visiting "fixya" today for your repair inquiries and good luck.
macmarkus :)
4/7/2010 4:00:07 AM • Asko T712... • Answered on Apr 07, 2010
Will not dry after 2 hours
Hello. Actually this is not a ventless dryer, there is a vent hose whic typically comes with the appliance. If the appliance is not vented out-of-doors it should at least be vented into the room. Pull the dryer out from the wall so you can inspect the rear of it and you will see the vent hole. If need be, go to any hardware store and purchase a dryer vent kit.
Here is a clip from the Asko T712 literature.
Easy to install Simply plug it into an electrical socket and connect the ventilation hose provided.
12/19/2009 10:28:05 PM • Asko T712... • Answered on Dec 19, 2009
My dryer wont stay hot
Check for a faulty high limit thermostat. It is a small round black device mounted on a metal plate. It is usually mounted to the internal ductwork with two screws. It can be tested for continuity using a multimeter or ohm meter. It should have no continuity. If it has continuity, it is stuck open and is faulty. I am attaching a pic showing a thermal fuse and high limit thermostat for reference. Hope this helps and best wishes.
8/17/2009 11:54:58 PM • Asko T712... • Answered on Aug 17, 2009
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
8/6/2009 2:14:17 AM • Asko T712... • Answered on Aug 06, 2009
Asko T712 Electric Dryer Logo
21 questions posted
Top Asko Dryers Experts
Mat Kramer
Mat Kramer
Level 1 Expert
Paul Carew
MattS1978
Level 1 Expert
Are you an Asko Dryer Expert? Answer questions, earn points and help others
View Most Popular
Asko Dryers
  • Asko Dryers
Most Popular Question
asko t721 dryer
  • Dryers
