20 Most Recent
Bosch WTA4410US Dryer Questions & Answers
No heat seems to work
heating element or hi and low heat thermostats,or burned wire,sugestion get a professional
Dryer not getting hot
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If you are having problems with your gas dryer not heating
the most common problem is that the ignitor goes bad. Even though it glows
sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different
things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Bosch Maxx7 sensitive - WTV74100ME/15 - stop after 1 minute , 3 beeps all the time , flushing lights together for heat and open door icon.
The issue you are experiencing with your Bosch Maxx7 sensitive dryer could indeed be related to a faulty heat sensor or a clogged vent. Here are a few troubleshooting steps you can try:
- Check the vent: Ensure that the dryer vent hose is not clogged or blocked. A blocked vent can prevent hot air from circulating in the dryer and trigger the overheat sensor to shut down the machine.
- Clean the lint filter: Remove the lint filter and clean it thoroughly. A clogged lint filter can also cause the dryer to overheat and shut down.
- Check the heating element: If the heating element is faulty, the dryer may not heat properly or may overheat and trigger the sensor to shut down the machine.
- Reset the machine: Turn off the power to the dryer for a few minutes and then turn it back on. This may reset the machine and resolve the issue.
If none of these troubleshooting steps resolve the issue, it may be best to contact a qualified technician to inspect and repair the machine.
2/26/2023 7:21:07 AM •
Bosch Dryers
Answered
on Feb 26, 2023
Water tank full (!) in bosch tumble dryer WTE86301gr
As a matter of fact I have solved the problem. The dryer is now fully functioning again. :-)
I'll try to explain how to fix the problem:
The water that condenses in the condensor (doh!) drips down into a container situated below the condensor. The moist air that passes through the condensor is the same air that circulates via the clothes, thus it also contains some lint that the filter doesn't catch. Over time there will be some build-up of lint and mucus (?), clogging the tank AND a sensor that sends a signal to the electronics to start the pump that evacuates the condensed water to the removable tank in the upper part of the machine. This messes up the function of the water evacuation system.
Alright, pull out the condensor and find a hatch in the 'floor' in the farther part of the compartment. Below the hatch you'll find the container that collects the condensed water. Start by cleaning it as thoroughly as you can. There are a few 'nooks and crannies', take your time, also flush with some fresh water and maybe some gentle cleanser to get rid of the mucus. The pump and the sensor for the pump are located in the left part (viewing from front of the machine) of the container. Try to flush there as well.
If this procedure doesn't solve the problem you'll have to disassemble the machine to also be able to remove the pump and sensor housing. I had to do this on mine. Quite a few screws to remove and keep track of, but pretty straight forward if aren't too uncomfortable with 'fixing things'.
I have some pictures of the 'project' somewhere, let me know if you would like to see them or if I may help you some other way.
BR /Hans
7/27/2022 7:02:58 AM •
Bosch Dryers
Answered
on Jul 27, 2022
