20 Most Recent
Crane Elephant EE-3186 1 Gallon Humidifier Questions & Answers
Why does the crane elephant humidifier leak
The humidifier has just started leaking from underneath the trunk part and drips down the front side and pools quite a bit underneath the humidifier causing quite a wet mess. This just started after I ordered a replacement water tank. Any suggestions?
I tryt to turn on my humidifier tonight.1st the
Welcome to Fixya!
- Ensure that the water tank cap is secured properly to water tank.
- Empty out water in water basin. Place filled water tank on to empty water basin.
- Clean Water Level Sensor.
Hope this helps!
No mist is coming out of it but the green light is
Hi Lisa,
- Check that there is water in the Water Tank.
- Make sure that nothing blocks the Mist Output Slots.
- Check that the Fan Vent on the bottom of the humidifier is not blocked.
- Empty the humidifier and rinse the Water Basin with cool tap water and allow to dry for 15 to 30 minutes before resuming normal operation.
- Check for possible mineral deposits on the Water Level Sensor or the Nebulizer.
For more information, check out the
owner's manual here. It is truly helpful!
Good Luck!
