20 Most Recent
Thermador Professional Series PO301 Stainless Steel Single Oven Questions & Answers
The door will not close completely
Hi someone lifted up on the door this ishowyou remove oven doors open the door about 1/3 then push down towards the floor it should go back into place, if not you may have to remove it clean the hinges then re-install it , I don't think anyone could have bent the hinges cause that would b very hard to do, but i have seen it done before , get back to me Frank
12/13/2011 1:48:36 AM •
Thermador...
Answered
on Dec 13, 2011
Burners won't ignite
Check your gas connection first. Check if the ignition is actually sparking.
1/4/2010 11:39:48 AM •
Thermador...
Answered
on Jan 04, 2010
From door on range came off when I tried to lift
Normally you force the hinges open and there will be a small hole to stick a nail in to keep them open. It is VERY hard to install the door if the hinges are trying to close it. You hold the hinges out with the nail while you install the door, then release the hinges to close by removing the nails.
8/11/2009 2:20:35 AM •
Thermador...
Answered
on Aug 11, 2009
Thermador SM272 - Oven not heating after self clean cycle
Your repairman might be right but I would have checked the main heating element first for this reason:
The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed.
Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
4/20/2009 2:25:11 PM •
Thermador...
Answered
on Apr 20, 2009
