20 Most Recent
Mastercool 67680 Evaporative Cooler Air Conditioner Questions & Answers
Shaft is stuck in the squirrel cage in swamp cooler how do i get it out?
If you are planning to replace the shaft;
if your able to loosen the 2 square headed bolts( which must be done to allow for shaft movement) do so, then after bearings and pulley are off emerycloth (smooth no burrs or rust) the shafts 2 ends and get grinder and cut thru the shaft on the inside of squirrel cage area as close to the edge of cage as possible drive the shortened pieces of the shaft inward( oil this pieces to help ease movement thru blower wheel) until they are removed replace shaft with new shaft and re-install parts and or replace as needed bearings and blower wheel. I am getting ready to do this very job myself ( take measurements of shaft on each side to ensure your back where you started when done)
We have an older swamp
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Dry pad
Check for plugged holes in the top water distribution tray where the water from the pump exits to wet the pads.
Changing squirrel cage GE window a/c
yes, most smaller window units have both outdoor and indoor cages connected to a single motor in the middle of the 2 blower wheels and are completely seperate from the compressor and it associated parts
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
