20 Most Recent Blodgett Combi® BC-142G Stainless Steel Gas Double Oven Questions & Answers
Temp not stable. temp jumps from 480 to 450 and
SOUNDS LIKE YOU HAVE A FAULTY TERMOSTAT REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
11/5/2009 11:45:32 PM • Blodgett Combi®... • Answered on Nov 05, 2009
Is there such a thing as a descaling unit for a
These combi ovens are so prone to problems if you do not have descaling filter system hooked to the COLD water supply (the only water that should be fed to this unit) for your generator inlet. The other water hookup is for your condensate drain (condenses steam leaving cook chamber headed down the drain) and it does not need to be filtered but, also needs to be COLD. These decaling units are quite pricey but, a service call to replace the generator (boiler in laymens terms) will cost 3 times as much & the unit will be down for days waiting on parts. Call Blodgett w/ your model # & talk w/ technical service & ask their recomendation. They can be reached @800-331-5842 & follow the prompts. Depending on your water conditions it is still recomended to descale the unit on a regular basis using a QUALITY descaler (not the junk you buy from Sysco or Dollar general) Cleveland descaler is the BEST.
7/25/2009 1:40:22 AM • Blodgett Combi®... • Answered on Jul 25, 2009
We have a Blodgett Propane Oven Model DFG100-1 would like to purchase another one, was wondering if this model is stackable?
yes it is, advise the salesman that you will stack the new oven with your existing one.
6/13/2022 6:24:31 AM • Blodgett Ovens • Answered on Jun 13, 2022
Blodgett 1080 E error code
Please go to google search engine.definitely you will get the qnswer.
11/1/2021 11:41:19 AM • Blodgett Ovens • Answered on Nov 01, 2021
Blodgett GZL-10 pilot is lit but won't fire up I have 2 of these convection ovens and first one and now both won't light up to heat suggestions
Door switch, gas valve, temperature control, selector switch?
2/9/2019 10:01:11 PM • Blodgett Ovens • Answered on Feb 09, 2019
I have an Old Lang EHS-T convection oven and need to replace the element. The part # is 2n-11090-24. I'm having difficulty finding this part. Is there a substitute I can use for this element?
Once after checking that the specs are the same the parts can be used in different equipment despite the various brands the spec are what is important alone with the dimenssion so that it can fit
12/31/2018 3:49:51 PM • Blodgett Ovens • Answered on Dec 31, 2018
I have a blodgett Mark V111 it is wired 3 phase can it be wired single phase
You can you have a lot of money.
4/3/2018 8:04:02 PM • Blodgett Ovens • Answered on Apr 03, 2018
Why is my blodgett 961 pizza oven flame orange
Dirty burner nozzles is the likely cause.
3/22/2018 8:12:37 PM • Blodgett Ovens • Answered on Mar 22, 2018
How to install door hinge on Blodgett oven
Model and serial numbers will help
2/10/2018 2:58:51 AM • Blodgett Ovens • Answered on Feb 10, 2018
How do I replace the oven glass on Blodgett DFG-50
it has been some time since I have done this but if I remember correctly, the replacement glass comes with a special tool for the trim around the glass and instructions. I suggest calling a supplier, such as Restaurant Parts and More, Heritage Parts, or PartsTown and ask if this is still the case that the tool and instructions are included with the glass.
12/17/2017 9:13:15 PM • Blodgett Ovens • Answered on Dec 17, 2017
Blodgett Combi® BC-142G Stainless Steel Gas Double Oven Logo
8 questions posted
Top Blodgett Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
View Most Popular
Blodgett Ovens
  • Blodgett Ovens
Most Popular Question
temp not stable temp jumps from 480 450
  • Ovens
