20 Most Recent
Hampton Bay AC418-OBB 60'' Brookedale Oil Brushed Bronze Ceiling Fan Questions & Answers
Hampton Bay Brookdale ceiling fan model 761-567.
I'm having the same issue, which is how I found your complaint. I googled the issue and your problem was the first to pop up. I have no idea how to fix it and I am wondering if you had any luck, or if you just went out and bought a new one?
CHAIN SNAPED THAT SWITCHES THE FANS DIRECTION
You will need to remove the fan, being sure to turn off power first. Then open it up and remove the old switch, and install the new switch. If you take the old one into a Home Depot or similar store they can help you match the switch. There are many different types, so take the old one in. I can't speak to the specific steps, but it should be pretty simple once the headache of dismounting the fan is over.
Bought a ceiling fan with
you can just go to lowes or home depot they carry them there easy to put in just use two people to place it up works a lot better dont forget turn power off first, good luck
How do we change the
hello lovesun... usually on the fans with out pull chains there is a switch on the top of the motor housing which you have to use to change the direction. Joe
