20 Most Recent
Honeywell RTH3100C - Digital Heat Pump Thermostat Questions & Answers
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
9/2/2014 12:02:30 PM •
Honeywell...
Answered
on Sep 02, 2014
RTH3100C thermostat for an older Lennox heat pump
well the wire on x will go to e thr r is the red wire goes to r the wire on f willgo to g the y will go to y now the rest you'll have to verfy at air handler o will go to reversing valve common wire will go to c the electric heat will go to aux
2/6/2014 5:05:22 AM •
Honeywell...
Answered
on Feb 06, 2014
Changing From Trane to Honeywell
Color ---> New stat terminal Blue--------C Green------G Yellow-----Y Orange----O Red---------R White------E and Aux. Tan---------unused, tape and secure it If there is Rh and Rc or R and Rh, these terminals should be jumpered together. I used to install Weathertrons eons ago. Whatever you do DO NOT connect the blue wire to the B terminal, you will short out your low voltage transformer immediately when you switch to heat
2/4/2014 3:38:33 AM •
Honeywell...
Answered
on Feb 04, 2014
Wiring a thermostat
Are you changing out thermostat? If so you must turn off power to your furnace or air handler. You should mark or write down each color and what terminal it was removed from. example= red from term r=green from term.=g yellow from y... Be careful, some thermostats are wired different according to type of system you have. Heat pumps are different than straight cools and the thermostats sometimes have setting or little switches. Honeywells have installer set up guides in package. Read it carefully
9/16/2012 7:40:32 PM •
Honeywell...
Answered
on Sep 16, 2012
Replacing a 2-pole baseboard heating thermostat
Here at home where I reside we have an old school thermostat that has the mercury bulb that acts like a sensor, and in other cases it could just be as easy as replacing the batteries in the unit itself, usually a lid that hides them, sometimes it works
1/29/2024 4:24:58 AM •
Honeywell...
Answered
on Jan 29, 2024
Hello, I have old Honeywell LR1620 thermostat. gas furnace and electric a/c. What options for a programable or non-programable Honeywell thermostat?
Here are some options:
Honeywell Home Non-Programmable Thermostats: These thermostats are designed for simplicity and comfort control. They come in a range of models, from the classic circular dial to easy-to-use soft-touch buttons and backlit displays. You can easily set your preferred temperature with the touch of your hand. The Honeywell Home website has a range of non-programmable thermostats to choose from .
Honeywell Home Programmable Thermostats: These thermostats allow you to set different temperatures for different times of the day. This can help you save energy and money on your heating and cooling bills. The Honeywell Home website has a range of programmable thermostats to choose from.
Honeywell Home Digital Non-Programmable Thermostat RTH5160D1003/E: This thermostat is simple and intuitive to use. It has a backlit screen and basic button functions that make it easy to control the temperature. Once you set your desired temperature, the thermostat stores it in its memory, even during a power outage.
Non-Programmable Thermostats ' Honeywell Home RTH5160D1003/E Non-Programmable Thermostat ' Honeywell Home Might as well look at the programmable ones on their site. Check their customer service if you have an additional question. The above mentioned should work with your setup.
1/15/2024 10:46:15 PM •
Honeywell...
Answered
on Jan 15, 2024
Where is battery on a Honeywell LR95329 Thermostat Base please?
They all hide in the thermostat base.
Load on the contacts is 24 vac standard, 30 volts max. the battery however is a standard AA or AAA Duracell battery, it is not 30 volts.... Those are available almost everywhere, You can pry the front of the thermostat from its wall mount sub base and see the batteries inside... just replace them.
Apr 18, 2017
12/5/2023 4:22:10 AM •
Honeywell...
Answered
on Dec 05, 2023
Need help replacing a thermostat
If you have wifi try the Hive Thermostat. Control your heating off your iPhone or with a touch of the button on the remote controller.
Otherwise there are many hard wired systems available.
Have a look here; https://www.hivehome.com/
8/20/2023 7:07:10 AM •
Honeywell...
Answered
on Aug 20, 2023
