my oven was converted to LP gas we move overseas.It worked for about a year then all of a sudden the oven stopped working. The burners work perfectly but the oven just keeps clicking after preheat is finished. We replaced the upper electronics board so what could it be now
Whirlpool F2 error code indicates that oven temperature is too high. And to fix this problem:
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just have your model # ready when you call.
F2 Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC). 2. For SELF CLEAN models: check door lock operation. 3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Sorry to read about your problem, I hope this helps you out.
if you can remove them, soak in hot water and clean, if you can't. clean the holes with toothpick or needle, etc.
take a match and start the burners, you may be able to see which holes are blocked..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
Thanks for using FixYa. Error F3-E2 in your Whirlpool oven means oven too hot and to resolve
this issue you'll have to replace the oven temp. sensor (probe). Please
rate the solution if the issue is resolved or post a comment for further
assistance.
e2-f3 meens your oven sensor is bad. if you look in the back wall of the oven you will see a probe a little smaller than a pensil held in by two screws. remove power then the screws and slowley pull the sensor into the oven far enough to unclip the wires. sometimes you have to remove the back to do this then replace the sensor.good luck! If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Does the glow bar get hot? If not you have other problems.The new valve might have a on/off switch, look for a little flip lever to turn it on. Some were shipped in the off position. Eric
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
have it calibrated, usually behind the knob when removed,
or more easily remember this and get a little oven thermometer , Theyre better anyways and the stat if not junk will maintain desired setpoint without much variance
If this is electronic ignition, then chances are the burner or ignitor nub has residue on them, preventing the flame detection system from keeping the gas on.
Use warm soapy water and a plastic scrub brush to thoroughly clean the burner cap, burner base, and ignitor nub.
