20 Most Recent Thetford RV Refrigerator - N300 Model - Type - 3-Way Questions & Answers
0answers
Smelling burnt gasses
Make sure your roof vent is not clogged immediately. If you are in a full service park, you should be running on electricity not propane. You don't describe the gasses you are smelling, if it is ammonia, your frig is probably done for.
Ammonia is the primary ingredient in the cooling process. What happens is the ammonia is boiled and then sprayed throug an orfice. The spraying creates the cooling (heat removing) effect. If you are smelling ammonia, your boiler has developed a leak.
You can purchase replacement units to install in your present frig. Some people have success with this. My experience was not so good. I spent about $225.00 plus shipping for a rebuilt unit (with a 'core' charge). I did the work myself. I got about a year out of the rebuilt unit before I simply replaced the frig with a new replacement 3 way Norcold. My new Norcold was much improved over the earlier model and included a ice maker! It was expensive, however, at more than $1300.00. Find sources for replacement cooling units for your "Thetford" refrig at FixYa.com advertisers or through your RV dealer or in the back of travel trailer magazines.
I hope this is NOT your trouble and I hope you find resolution. Thank you for your interest in FixYa.com and please come again.
7/24/2011 6:34:43 PM • Thetford RV... • Answered on Jul 24, 2011
Model 12110 IM Norcold-not cooling
Hi, if the burner lights in the 'gas' mode, the control board is OK. You most likely have a leak in the sealed refrigerant system, and you need to have the leak located and repaired. This is a job for a RV refrigeration technician. If you need to find the nearest Norcold authorized service dealer, go to www.thetford.com, and use their dealer locator menu.
4/13/2011 7:11:04 PM • Thetford RV... • Answered on Apr 13, 2011
0answers
Norcold fridge does not stay cold.we turn it to lp
Quit playing with it ... absorption refrigs work slow ... and do not recover well ... If yours has a thermostat ... set it a little lower ... check it in the morning ... use a thermometer inside. Keep track of the temps.
Putting warm food in the frig will result in a big slowdown in recovery.
Thanks frr using FixYa.com
10/5/2010 1:51:57 AM • Thetford RV... • Answered on Oct 05, 2010
Thetford N90 EL.L built-in has stopped
If it won't cool on all 3 power sources the cooling unit is probably faulty. Contact Thetford asap if the unit is uner 3 years old as it should be under warranty. Thetford won't sell a replacement cooling unit, their only answer is that you need to buy a new fridge at over £600. I have this problem too and am looking for another solution but to luck so far
5/1/2010 1:46:12 PM • Thetford RV... • Answered on May 01, 2010
2answers
Refrigerator on rv keeps going out
Two reasons, first would be that the burner is dirty and needs cleaning. Second is that the thermocouple is either faulty or incorrectly installed. By this I mean that it might be slightly too far away from the flame to be able to conduct sufficient heat to keep the thermocouple open. This can happen when you park or drive and the rv is at different angles. So the flame does not heat the thermocouple enough and it shuts off the supply.
7/4/2009 10:11:36 PM • Thetford RV... • Answered on Jul 04, 2009
The off on button on our thetford fridge does not turn off it flashes blue non stop with or without power source
Hi, Your fridge might have a battery packed attached to it. This would be one thing that could cause your fridge lights to still function even without being plugged into an outlet. Thank you.
9/26/2022 7:18:54 PM • Thetford... • Answered on Sep 26, 2022
Thetford N112-N41F04L6E Fridge Not cooling
check safety circuit if ok possible control board or cooling unit bad if unit comes on bad cooling unit also check temp sensor if unit comes on
6/26/2021 5:21:50 AM • Thetford... • Answered on Jun 26, 2021
2answers
We have a thetford 3 way fridge that keeps freezing our food especially liquids such sa milk and juice
In most cases the thermostat is not operating as it should. First see if the probe is still in its clip on the fins of the evaporator ( the thing in the back ) if it is still in position the thermostat is most likely bad.
9/11/2020 4:51:53 AM • Thetford... • Answered on Sep 11, 2020
Thetford RV Refrigerator - N300 Model - Type - 3-Way Logo
Popular Tags
20 questions posted
Top Thetford Refrigerators Experts
john h
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Thetford Refrigerators
Most Popular Question
refrigerator rv keeps going out
  • Refrigerators
