20 Most Recent Adaptec 29320 SCSI Controller Questions & Answers
Getting the following error repeatedly: A parity
Any "Parity Error" is from a communication error on the SCSI bus, and it's bad! Errors are a way of life, and the SCSI transceiver has failsafes to fight them, and one of these is parity. Consider it extra data that the controller sends when you transfer data to your hard disks. Once there, the drives transceiver does a simple ccheck and verifies that the parity is correct. If not, a Parity Error is generated. 99% of the problems surround the SCSI bus itself in the form of a damaged SCSI cable, loose terminator, or a bent pin on a SCSI connector (latter being most common). This error is more apparent after moving the SCSI devices, resulting in unplugging and then replugging the cables back onto the Targets (HDD, CD/DVD ROM, printer, etc.) or back onto the Host Bus Adapter (HBA - the 29320 in your case). Check ALL pins. You can try to straighten the pins, otherwise it's time to replace the cable. REMEMBER that terminators are a must and can also cause Parity Errors if there is no termination present on one end of the bus or the other.This coming from an ex-Adaptec employee and support person! :)Best of luck
10/28/2011 1:58:42 AM • Adaptec 29320... • Answered on Oct 28, 2011
0answers
Adaptec 6405
Be the first to answer 2/17/2018 9:45:02 PM • Adaptec... • Posted on Feb 17, 2018Be the first to answer
0answers
0answers
Adaptec afw 8300
Be the first to answer 12/26/2013 11:18:29 AM • Adaptec... • Posted on Dec 26, 2013Be the first to answer
0answers
TMC N0TINITIALIZED
Be the first to answer 10/16/2013 7:30:11 AM • Adaptec... • Posted on Oct 16, 2013Be the first to answer
Is there a high-gain antenna
check with your local computer store for this issue.
There should be an antenna on market that is compatible.
I would relocate the router in another location and see if the reception is better. Try to relocate the router away from cell phones or cordless phone and or digital TV's about 20 ft is desirable.
8/7/2010 6:58:54 PM • Adaptec... • Answered on Aug 07, 2010
Delkeyboard not find a driver for 97976 General
you can ues windwos vista drivers they work on windwos 7, or you can download it from http://tinyurl.com/6qwma
just enter the service tag and select the operating system if windows 7 is available in the list select that otherwise use windows vista.
3/29/2010 4:48:47 PM • Adaptec... • Answered on Mar 29, 2010
Find the surface area of awooden box whose shape
If this box is a cube, and each side is 15cm long, then each side has an area of 225 square centimeters. Since a cube has 6 sides, your cube's total surface area is 1350 square centimeters. This was a fun change from the normal question... but I don't get what you're trying to do. Thanks for the question.
3/4/2010 3:07:23 AM • Adaptec... • Answered on Mar 04, 2010
Regarding the drivers of neo b2300 n... I
On the drivers download page it shows clearly Microsoft Windows Vista® and XP Drivers
http://www.neo.com.ph/support_dloads_basic_08.aspx
2/2/2010 9:32:28 AM • Adaptec... • Answered on Feb 02, 2010
I have a pasaris cam but i liost their driver cd
my computer is no sound plese give me the driver of sound
1/11/2010 1:37:59 PM • Adaptec... • Answered on Jan 11, 2010
Adaptec 29320 SCSI Controller Logo
1 questions posted
Top Adaptec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Adaptec Computers & Internet
Most Popular Question
getting following error repeatedly
  • Computers & Internet
