20 Most Recent
Whirlpool 21 in. RCS2002LS Electric Cooktop Questions & Answers
Large burner not operating
do a continuity test on the burner itself if you have continuity in the burner then you would check for power at the receptacle to assure that you have power at the receptacle please remember to rank how this opinion has helped in your appliance situation and if i can answer any futher questions message me back thanks again
rickead1
The burners pop whenever the gas is on
You didn't mention if it only pops when you first turn them on or that the popping is continuous.
If it when you first turn them on, then I would suspect late ignition. Too much gas build-up before ignition takes place. The spark gap may need to be adjusted or the spark module replaced.
If it happens continuously there may be a short in one of the switches or wiring harness.
6/1/2014 7:06:30 PM •
Whirlpool...
Answered
on Jun 01, 2014
Westinghouse 808 cooktop clicking noises
Sometimes after a power failure the p c board needs re setting. Turn off the power for a few minutes that allows it time to re set. Turn it back on then individually turn on each element for a couple of minutes.
5/10/2014 11:47:16 PM •
Whirlpool...
Answered
on May 10, 2014
