20 Most Recent
Avaya Definity 8410D Corded Phone Questions & Answers
I need a user manual
http://minerva.stkate.edu/internal/docroom_helpguide.nsf/files/8410/$file/8410D.pdf
or, Google for "lucent 8410D filetype:pdf" to find other similar manuals.
My Avaya/lucent 8410D phone got
Hi,talking from experience,i will suggest you contact phone engineer in your area to carry out a check on the major components of your phone such as the earpiece,mouthpiece,LCD etc which might have been damaged(70%probability) as a result of the great shock experienced when it fell apart,
It won't cost me anything to give you the proper orientation of the hangup plunger wire,but you not knowing the orientation of this wire,which if i describe to you,you may end up doing it wrongly which poses a great risk or electric shock according to avaya,how are you sure some basic components have been installed properly by you.
So please take caution,contact a phone engineer in your area to assist you
Thanks and take care
How to set intercom
Hi
Phone functions are set on the pbx on the station form, not on the phone itself
check support.avaya.com for further info
HOW TO INSTALL AVAYA PHONE 8410d 1 line at home
First, buy an Avaya Definity system. Then learn to program the system. Then you will know.
That phone will not work without the control unit. The conrtol units cost a few thopusand dollars and about 1 month of training to install.
Voicemail access
Which phone system? Which voicemail system. There are ways, but most cost money.
How do you change the time on an Avaya 5420 phone
Avaya Phone Change Date and Time
Avaya/Lucent Partner ACS Phone System
- Press Feature and dial 00.
- Press the left intercom button twice.
- To set the time, press # and dial 103. Enter the correct time using a 24-hour format.
- To set the date, press # and dial 101. Enter the correct date using MMDDYY format.
- Press feature and dial 00 to save.
