20 Most Recent Dell Mms 5650 5.1 Surround Sound Home Theater 6 Speaker System Subwoofer Mms5650 Questions & Answers
What type of fuse is used in the subwoofer?
Hugo Sepulveda, The subwoofer uses the T1.6L250V fuse. You can get this at your local hardware store. Thank You, Dell-Jesse L Dell Social Media and Communities
10/26/2015 3:38:41 PM • Dell Mms 5650... • Answered on Oct 26, 2015
Mms 5650 small amplifier ic number required
Hi,Would you please give me more information, as the number of pins of the ic,? does it has just one screw above in the metal flange?TDA7293 comes to my mind...let me know to help further..
11/6/2013 4:29:42 AM • Dell Mms 5650... • Answered on Nov 06, 2013
2answers
How to take apart a dell mms 5650 subwoofer
funny thing about speakers is that they need an enclosure to work properly in the unit has a back and the car has a door skin or other enclosure to work in
11/5/2023 4:16:00 AM • Dell Audio... • Answered on Nov 05, 2023
Dell Jukebox Rescue Mode Have read other posts but still need help
Back it up to a computer and do a full factory reset. I just read your question tagged onto an old post. You should not be using this device to store important class notes. It is so old it could fail at any time. Notice in the link what Dell says in the manual Whenever I turn my Dell DJ on, it starts up in Rescue Mode. Your Dell DJ's firmware or operating system may be damaged. Go to support.dell.com for the .. https://www.google.com/search?q=Dell+Jukebox+Rescue+Mode ..
6/5/2023 6:33:20 PM • Dell Audio... • Answered on Jun 05, 2023
How do i open my speakers, there's no screws
Click here to follow these steps https://mybestspeakers.com/how-to-take-apart-speakers-with-no-screws/
12/15/2021 6:41:17 AM • Dell Audio... • Answered on Dec 15, 2021
2answers
I have Dell speakers, hp tower, I can't get sound out of speakers. Do I plug both the usb plug & speaker plug into tower?
If there is no separate power supply the usb plug must be used in order to provide power for the speakers, but whether the analogue cable must be plugged in or not will depend on the internal construction and specification of the speakers. I suggest you initially use the usb and if there is no sound and no on-screen instructions, plug in the analogue line. If there is a separate power supply the speakers are probably and either/or design.
12/4/2018 4:19:38 AM • Dell Audio... • Answered on Dec 04, 2018
2answers
My Dell P32E just all of a sudden started having static and dragging when playing music and also some static when not playing music. This is my lifeline! How do I fix it?
what is 'dragging'? most likely dirty contact on the plug from computer to the speakers.
10/3/2018 12:02:00 AM • Dell Audio... • Answered on Oct 03, 2018
Hello there..I've got a Dell
Windows has a troubleshooter for the audio system in most computers. Get the "fix" here: https://support.microsoft.com/en-us/help/4026994/windows-fix-sound-problems Good luck!
1/14/2018 6:06:10 AM • Dell Audio... • Answered on Jan 14, 2018
My applications last only as long as I leave my computer on. How can I make them stick?
Is there a battery back up somewhere on your computer? It could have failed. Or at least something connected with it. It could be an electronic fault. Bad capacitors etc. I assume they have ruled out a virus?
11/24/2017 8:07:05 PM • Dell Audio... • Answered on Nov 24, 2017
Background noise recording with dell
Get a wired lapel microphone and plug it into the microphone input on your Dell. The onboard mic is designed to record all ambient sounds. You want a different product to get the result you're looking for.
5/20/2017 2:35:03 AM • Dell Audio... • Answered on May 20, 2017
Altec Lansing ADA 745 speakers.
you need an amplifier
5/6/2017 10:26:40 AM • Dell Audio... • Answered on May 06, 2017
Setup Altec Lansing BX1220 speakers usb-powered...green 3.5 in back with usb next to it. I have a windows 10 free upgrade on a rebuild Dell Optiplex 755 vista desktop.
Forget the upgrade to windows 10, Dell doesn't recommend you do this as it disables some programs. I have the same computer.
9/23/2016 7:15:53 PM • Dell Audio... • Answered on Sep 23, 2016
Dell a525 speakers. One side is louder than the other. What can I do to fix this problem?
adjust the balance knob to center position
5/30/2016 5:47:12 AM • Dell Audio... • Answered on May 30, 2016
How do I find driver for my speakers. Disc not available. They stopped working after MS update.
My daughter had the same trouble with her Dell computer. The guy who was reloading Windows found the additional drivers on the Dell website. The Dell recovery disc supplied with a new machine already contain those drivers.
2/23/2016 10:30:26 PM • Dell Audio... • Answered on Feb 23, 2016
Dell Mms 5650 5.1 Surround Sound Home Theater 6 Speaker System Subwoofer Mms5650 Logo
7 questions posted
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Audio Players & Recorders
Most Popular Question
type fuse use in dell model 5650
  • Audio Players & Recorders
