20 Most Recent
Radio Shack 433575 Cordless Phone Questions & Answers
We've moved and need to
You can download the manual at
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4303575_PM_EN.pdf
Need ringer turned back on .. radio shack 5.8GHz
Hit the up or down arrow keys several times. (either key will work) and the ringer will rotate through Ringer off - Ringer low - Ringer high... one set will be a steady ring, the other set will be a warble ring. This works on the phone made for RadioShack with 5.8 GHz on the front and Cat. No. 43-155 under the battery in the battery compartment.
We have a Mod#01A00 Base
I have never seen the phone sold separately, the phone and base are security matched at the factory so nobody can ease drop on your calls, so even if you could find one I don't think it would work.
I need to know how
Hello. Take the phones and the base to your nearby radio shack store. Tell them what you need and they will take care of it for you. They will also check out the phones, and the base charging system. Truly a wonderful service. Joe
My cordless 2.4GHz phone has
From the handset that came with the unit (if you bought additional habdsets they may not have the following menu option -- for some reason only some of my handsets allowed me to do the following), press MENU/MUTE, press the up or down buttons to select DIAL MODE, press SEL/CH, press up or down button to select the mode (I believe it is "pulse" but may be the other option), press SEL/CH (the phone will beep), press END to exit. This worked for me.
I can call but when somebody calls me I cannot
In any phone cordless // Mobile or landline there are two things one is microphone & other is speaker. Microphone is when u speak caller party can hear u & speaker is to hear when someone from otherside speak. In ur case the speaker might be faulty get it repaire by the local technician
