20 Most Recent
GE 25861GE3 Twin Cordless Phone Questions & Answers
I need a downloadable manual
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/25861_CAN_EN_CL_IB.pdf
If you print the whole page as it is, you won't be able to read it. You can adjust the view to show larger text and then print the current view. The exact procedure depends on the version of whatever program you're using to view/print the PDF file.
My answering machine is in
Press the flash/prog button until 1ENG 2FRA 3ESP shows on the display.
Use the CallerID/Vol (+ or -) button or the handset number pad to select 1 (English) 2 (French) 3 (Spanish)
Press the flash/prog button to confirm and to advance to the next menu item.
I hope this helps. Have a great day.
GE 5.8 mod 25922fe1-a
hit the # you want then hit the mem button. Enter the name, hit mem again, then enter number, hit mem again and will be saved
How to set date and time?
If you are trying to set the date and time for the answering machine the buttons to do that with are on the right side of the main phone base.
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
