20 Most Recent
Whirlpool SCS3014LS Gas Cooktop Questions & Answers
Conversion NG to LP for whirlpool SCS3014LS, Colored spuds go where
Part number is 3192741 for the conversion kit going from Natural to LP. Cost is 25.00 through us. Should you choose to order, follow this link to our website where you can scroll down and fill out the secure order form to process your order. https://www.affordableappliance.com/orderform.php If you have any problems, concerns or need further information, feel free to reply to this email or for Parts Order Only, call 570-622-6441. Keep in mind ordering through us helps continue this free on-line help available for you and many others. Help those that help you. Waiting to hear from you,Eric & Ann Campion
3/24/2012 7:53:05 PM •
Whirlpool...
Answered
on Mar 24, 2012
Spark ignitors went on stove top
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
7/17/2010 12:22:53 AM •
Whirlpool...
Answered
on Jul 17, 2010
