20 Most Recent Panasonic KX-TG5631 Cordless Phone Questions & Answers
No display blank screen
hi sir. the problem is the flex wire of the display on the handset unit and this is common. you have 2 solutions. first change for a new the handset unit. or open the handset, remove the main board, separate slowly the display screen from the main unit. whit a hot air gun, give some hot to the white flex on the main board side(not too much or you can destroy that). and tighten a little with your fingers on the flex and the main board. This should paste the flex.
12/3/2013 12:50:53 PM • Panasonic... • Answered on Dec 03, 2013
0answers
Dropped the phone unit into water last nite, tried
You need to try Silica Gel Packets to dry out your phone. There was a good article on associatedcontent.com that explains how to dry a wet cell phone, iPods, or any electronics.
You need to place your cell phone in a zip lock bag with Silica Gel Packets. Silica Gel will remove all the moisture from the phone and its components, something air drying will not do!
Just Google "Silica Gel Packets" and you will find several companies selling these products. There is also a web site called: http://www.SilicaGelPackets.com that has them.
Sources:
http://www.associatedcontent.com/article/1028188/how_to_dry_out_your_iphone.html?cat=15
3/6/2011 9:11:15 AM • Panasonic... • Answered on Mar 06, 2011
Phone
You might try removing then replacing the battery. After trying everything recommended in the manual this is how I restored normal operation.
1/30/2011 3:34:20 PM • Panasonic... • Answered on Jan 30, 2011
This question is in regard
It is possible that the mic hole is blocked and the voice do not detect properly to be processed.
clean and check if not the mic might be faulty , use a new one and test as this is inexpensive. if not the preamplifier of the mic or the amplification stages of the mic is faulty.
A good signal test can prove corrrect.
9/20/2010 4:47:42 PM • Panasonic... • Answered on Sep 20, 2010
Screen on all three handsets
It is possible that your set was stored up and could have resulted in some build up of moisture and crusting on the PCB due to even faulty battery. First of all open one set and check within for cleaning of PCB , check on the display section and see if the cords are intact. clean the display terminals with a clean swap and reset. Check after connecting with the battery for any display. Use a hair dryer for warming up the display area and the PCB. solder suspected joints. Now check for voltage to the display processor , if not voltage is present trace to the main voltage section for any failure of the pedestal voltage to the micro processor and allied circuits. If not there is a possibilty that the display is damaged But I doubt so becasue it cannot happen to all the sets. I hope the set is triggered on but without display in which case you must check on the display unit supply Voltage. So do this one by one and I hope you come to the fault. Good day
8/11/2010 5:09:41 AM • Panasonic... • Answered on Aug 11, 2010
No display
Phone works fine but no display. Batteries are good.
4/19/2010 2:42:26 PM • Panasonic... • Answered on Apr 19, 2010
2answers
No digital display on handset and battery is fully
pls check the display meter
4/19/2010 2:31:01 PM • Panasonic... • Answered on Apr 19, 2010
2answers
Panasonic kx-tg5971al kids played with
When it ask for unlock press "0000" and then it will get unlocked. Also try this, without lifting the handset, press *#1234
Click on the link below to download the Panasonic KX-TG5971AL user/owners manual:
http://www.panasonic.com.au/support/downloads/more_info.cfm?objectID=1937&fileTypeID=2&productCategoryID=33&productID=0&listQueryString=fileTypeID%3D2%26productCategoryID%3D33%26productID%3D0
1/20/2010 6:24:28 AM • Panasonic... • Answered on Jan 20, 2010
My phone isn't communicating with the base...HELP!!!!
Its time always become two hours early than actural
4/24/2009 8:55:58 PM • Panasonic... • Answered on Apr 24, 2009
2answers
How do u get your Panasonic house phone working model number is kxtga850e keeps saying no link to base reconnect main base ac adaptor
It sounds like the phone system base station is burned out.
2/3/2024 8:19:25 AM • Panasonic Lands... • Answered on Feb 03, 2024
My phone is always on MUTE. How do I turn that off?
Press the mute button to turn mute off.
12/27/2023 5:21:29 PM • Panasonic Lands... • Answered on Dec 27, 2023
Panasonic KX-TG5631 Cordless Phone Logo
34 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
no display blank screen
  • Lands Phones
