20 Most Recent
Whirlpool MH6140XK Microwave Oven Questions & Answers
WHIRLPOOL MICROWAVE GIVING F-7 CODE
hello sir
you are right magnetron is fully interrupted.......
but tell me
!. do you want to repair machine( 4 sec problem)
2. do you want to buy inverter , magnetron
please tell i am ready to help you sir
I believe that is a microcomputer board failure. You will have to replace this board. Website below.
I have gotten parts from "repairclinic" on line and they worked fine. I saved $600 on the last repair of an oven. Good luck.
or sir you can find and fix each and every type of code error
http://www.applianceaid.com/micro_faultcodes.html#WLP
7/14/2017 10:20:13 PM •
Whirlpool...
Answered
on Jul 14, 2017
Re Microwave: we turned it own and then there was
test this components and fix it. God bless you
- Check the power diodeThis
electronic component is responsible for transmitting current in one
direction. If the diode becomes defective it will cause your microwave
to not heat. Test the diode and replace it if necessary.
- High voltage capacitorResponsible
for storing electricity, this part is a key component in any microwave.
Remove, discharge, and test the capacitor to determine if it requires
replacement.
- Damaged magnetronResponsible
for generating waves and producing heat. When your microwave is no
longer heating properly, replacement will be required.
- Thermal CutoffsExamine
the thermal cutoffs on both the magnetron and the oven itself. Take off
one of the leads and using a volt-ohm meter on RX1, check the terminals.
If you get a result other than zero, replace the thermal cutoffs.
10/25/2013 12:53:39 PM •
Whirlpool...
Answered
on Oct 25, 2013
Microwave wont heat
If it has a turntable does that move? If it moves and does not heat suspect inverter board (power) or less likely the Magnatron.If table does not move it could be a issue with the safety switch which the door engages when closed.
10/15/2012 3:50:57 PM •
Whirlpool...
Answered
on Oct 15, 2012
Microwave does not heat or turn
The problem may be in the door latch, "one or more is defective" often caused by food particle build up or latch failure, this will prevent the microwave from running.
3/6/2012 4:40:23 AM •
Whirlpool...
Answered
on Mar 06, 2012
I have asked a question, and it is posted as a
So you ended up answering your own question with the exact same original question?
You must be a psychiatrist.
It was probably just a temporary or intermittent glitch.
This question / comment that you posted here seems to have arrived in the proper spot normally.
Just try again with your original question and it should work.
Good luck, sorry about the inconvenience.
Joe.
10/3/2011 8:32:06 PM •
Whirlpool...
Answered
on Oct 03, 2011
Need new door glass
Hello there and welcome to fixya
You can either get this glass from the manufacture or there is a site called repair clinic.com that does have this glass . I was just there and they have it
Here is the info
Inner Door Glass
Item # 830392
Inner microwave door glass
Manufacturer Number 8172125
More
Promo Price
$82.70 $74.45
Quantity:
Out of Stock
(usually ships within 7 - 14 days)
1-800-269-2609 for calls within the 50 states.
1-734-495-3079 for calls from US Territories and APO/FPO bases.
Orders received by fax are processed within one business day.
1-734-495-3842
9/16/2011 7:02:26 PM •
Whirlpool...
Answered
on Sep 16, 2011
Where is the location of
Hello
& Welcome to FixYa
You
can check this parts image, part#13 is the magnetron located next to the
turntable plate. Please get back to me if you have any other questions.
Kevin
8/24/2011 1:48:30 AM •
Whirlpool...
Answered
on Aug 24, 2011
The Magnetron is out on
Replacing a magnetron typically is not that difficult. What you mostly have to consider, however, is safety. Most of these ovens generate about 3,000 to 4,000 VAC in the high voltage network where the magnetron is located. In order to replace the magnetron safely you must perform the following steps:
1. UNPLUG the microwave.
2. If the oven is an over-the-range model, you will need to unmount it. The oven is usually mounted in a rear bracket on the wall with two long screws holding it in place from the top. Locate the two screws holding the unit in place on the TOP of the oven and gradually loosen them to lower the oven. A second person to help support the oven is usually a must. Remove the glass carousel tray before doing this to avoid having it fall out and possibly break. (If you have a counter top model skip this step).
3. Locate the screws holding the exterior case in place and remove them. Remove the exterior case and set aside. NOTE: Some manufacturer's install these cases using special tamper resistant screws. They do this to prevent consumers from opening the appliance to work on them. If you notice the screw heads are different, many appliance stores (such as Sears) sell a nut driver with special attachments made for this purpose. The cost is usually less than $30 U.S.
4. Once the case has been removed locate the High Voltage Circuit. You can't miss it. There should be warning labels. Remove the protective guard the covers the circuit and remove.
NOTE: Some consumers have had concerns over the High Voltage Capactor (shaped like a can with two wires attached to it) for fear that it will hold a charge and cause an electric shock. Most of these capactors don't hold a residual charge for long. In fact, by the time you unplug the appliance and remove the exterior case, it will have discharged. If in doubt, you can discharge the cap by using a shorting probe. You can fashion one by using a screwdriver and some wire with an alligator clip on one end. Just clip the alligator clip the equipment chassis and wrap the other end several times around the screwdriver (make sure you strip the wire bare before wrapping around the screwdriver). Hold the handle of the screwdriver and touch it to all the component leads in the high voltage circuit. In particular the high voltage capacitor.
CAUTION: DO NOT operate the oven with the case removed, or try servicing anything with the unit plugged in.
There are several good websites that you can use as a reference that have exploded view parts illustrations:
searspartdirect.com
pcappliancerepair.com
appliancepartspros.com
Use these sites to locate and identify any parts to avoid confusion.
Removing and reinstalling the magentron at this point should be fairly simple. There is one (sometimes two) plug to remove from the filament and several screws holding it in place. Make sure you have the safety shield and exterior case reinstalled prior to testing the oven. Place a glass of water in the oven before test operating. The water acts as a load for the RF and will also indicate whether or not the magentron is working properly. The water should be near boiling within 2 minutes on most ovens. DO NOT operate an oven when it is empty. This can damage the magentron.
If you have any questions, please let me know. I hope this helps you.
8/10/2011 6:29:16 PM •
Whirlpool...
Answered
on Aug 10, 2011
I have the replacement part
Here is a link to the schematics and parts list for that model which shows an exploded view diagram of how the door parts are assembled:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=264471&diagram_id=28287680#d28287680
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Just click on diagram number 2 (DOOR) on the left hand side of the page.
You will need to remove the interior retaining screws on the door and disassemble the door components in order to access and replace the grill.
Good luck.
Joe.
6/20/2011 4:36:06 PM •
Whirlpool...
Answered
on Jun 20, 2011
