20 Most Recent Whirlpool MT4070SK 700 Watts Microwave Oven Questions & Answers
2answers
Stuck Microwave door
In most cases this is due to a broken door opening lever or loose or broken door latch / hook parts. They can only be accessed and examined if the cover is removed from the microwave. In many over the range models, you can access the door parts by removing the control panel assembly. Sometimes you may be able to get it open by pushing up gently on the bottom of the door while pushing the button, in case you need to empty it.
8/28/2010 3:37:05 AM • Whirlpool... • Answered on Aug 28, 2010
The button assembly or the arm thats attached to the push button is broken. With the unit unplugged. Carfully take off the screws from the sides and around the back of the unit around the outside of the cover. Now once apart, DO NOT TOUCH any electrical parts. Look at the mechanism and see if you can see why the buttons not activating an arm to trigger the door latch. If you think you see why, Go to http://www.repairclinic.com and enter your model #.. Answer the questions and then a bunch of parts will come up. If they dont then get the tele # from there and call them. Depending on how old the oven is, you may want to consider a newer oven??. Good luck
7/30/2006 7:19:04 PM • Whirlpool... • Answered on Jul 30, 2006
Oven with microwave function Whirlpool MWN 400S Ikea Nutid: after the end of any mode even after 5 sec of microwave - NO heating! cooling fan doesn't stop until open the door or press Stop button.
Get the door safety interlock switches tested for continuity and alignment, by a qualified service engineer. If a door switch is not switchimg. there will be no power to the magnetron and no heating.
1/30/2024 7:08:17 AM • Whirlpool... • Answered on Jan 30, 2024
Whirlpool WMH53521HZ Microwave Oven. Hello. I need the tech sheet/ schematic diagram for it please.
Question edited for clarity and typos. This is the only one available online. Microwaves are so inherently dangerous inside, Service Manuals are strongly restricted from public access. Make sure his medical and life insurance is up to date. http://www.uncleharrywizard.com/nephewclub/wizardrange/whirlpool-kitchen-aid/8178573-km-30-whirlpool.pdf Have a read. The Triac will be hard soldered to the mainboard or power board, so just look for the one with the same number. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
10/3/2023 4:56:53 PM • Whirlpool... • Answered on Oct 03, 2023
Whirlpool Microwave / Oven. It is showing 'DOOR' when I press Start.
  1. Clean the door sensors: If your microwave is showing "DOOR" when you press start, it's possible that the door sensors are dirty or obstructed.Try cleaning them with a soft cloth or cotton swab23.
  2. Replace the door switches: If cleaning the door sensors doesn't work, it's possible that one or more of the door switches are faulty and need to be replaced. You can follow this video tutorial to replace the door switches yourself3.
If none of these steps work, it's best to contact a professional or the manufacturer's service center for further assistance. I hope this helps!
8/27/2023 3:25:08 PM • Whirlpool... • Answered on Aug 27, 2023
Where is the fuse for whirlpool microwave model number WMH31017HZ07.
The fuse for the Whirlpool microwave model WMH31017HZ07 is located inside the microwave oven. You will need to remove the outer cover of the microwave to access the fuse. Here are the steps to follow:
  1. Unplug the microwave from the power source.
  2. Remove the screws on the top of the microwave that hold the top grill in place. Remove the grill.
  3. Locate the screws that hold the control panel in place. Remove the screws and carefully pull the control panel forward.
  4. Locate the fuse holder on the right side of the control panel. Remove the fuse holder by pulling it out.
  5. Check the fuse to see if it is blown. If it is, replace it with a new fuse of the same type and rating.
  6. Reinstall the fuse holder, control panel, and top grill.
  7. Plug the microwave back in and test to see if the light is working.
If the light still does not turn on after replacing the fuse, there may be another issue with the microwave and it may require further troubleshooting or repair.
2/26/2023 10:32:17 AM • Whirlpool... • Answered on Feb 26, 2023
Whirlpool oven is stuck in demo mode, model wos72ec0hs01
To Start Demo Mode
  1. Select the Tools keypad.
  2. Scroll and select INFO.
  3. Select Store Demo Mode and select ON. NOTE: The display screen will show the time
  4. Select the Tools keypad.
  5. Select Try the Product or View Product Videos.
To Exit Demo Mode:
  1. Select Try the Product.
  2. Scroll and select Explore.
  3. Select the Tools keypad.
  4. Scroll and select INFO.
  5. Select Store Demo Mode and select OFF.
  6. Select YES on the confirmation screen.
link copy and paste https://producthelp.whirlpool.com/Connected_Appliances/Product_Info/Videos/VIDEO%3A_Entering_and_Exiting_Demo_Mode_-_Smart_Appliances ..
2/23/2023 4:42:37 PM • Whirlpool... • Answered on Feb 23, 2023
Whirlpool AKP 745 NB - just blink
It sounds like you are experiencing an issue with your Whirlpool AKP 745 NB oven. The fact that the oven is only blinking with an "auto" text suggests that there may be an issue with the electronic control panel. A possible solution is to reset the oven by unplugging it from the power source for a few minutes, then plugging it back in. This can help to clear any temporary issues with the electronic control panel. If the problem persists, you may want to check the user manual for any specific troubleshooting steps or contact the manufacturer for assistance. Another possible solution to try is to reset the oven by pressing a certain combination of buttons on the control panel, as the manual suggests. If the problem still exists, it is advisable to contact the manufacturer or a professional technician for repair. It's important to note that, electronic control issues can be caused by various problems, so it is best to refer to the user manual or contact the manufacturer for more specific troubleshooting steps and to get a more detailed diagnosis of the problem.
1/18/2023 6:51:14 AM • Whirlpool... • Answered on Jan 18, 2023
How do i get to the fuse on a Whirlpool microwave MH1170XSS
A bad fuse is one of the most common problems on microwaves, including Whirlpool ovens. Most modern microwaves use the same style of fuse which you can find at most appliance and electronics stores. The difficulty of replacing the fuse in a Whirlpool microwave can vary depending on whether you are working on a countertop microwave or a built-in. Knowing where to start can make the process much easier for either style of microwave. Countertop Microwaves Step 1 Unplug the microwave and let it sit for a few minutes before beginning repairs. Bring it to a clear area with enough room to work. Leave enough room to have access to it on all sides. Step 2 Remove the Phillips screws from the outer shell of the microwave. The screws are located along the lower sides and around the edges of the back. Put the screws into a bucket or bowl to keep them together. Pull the shell away from the microwave, and set it to the side. Step 3 Look for the fuse inside the exposed controls of the microwave. The fuse is located in a small receptacle with two wires running to it. Use a flat screwdriver to pry up from the bottom of the fuse. The fuse will pop out. Replace the fuse with a new one. Built-in Microwaves Step 1 Unplug the microwave, and let it sit for a few minutes before beginning repairs. Step 2 Open the microwave door, and look for two Phillips screws along the left side of the control panel. Remove these screws. Lift up on the control panel, and tilt it outward. The control panel will rest on its hinges. Step 3 Find the fuse receptacle within the control area. Is is usually located to the left or center of the cavity. You will see two wires that go to either end of a small, plastic receptacle. Use a flat screwdriver to pry up on the bottom of the fuse. The fuse will pop out. Replace the fuse with a new one.
1/16/2023 11:21:18 PM • Whirlpool... • Answered on Jan 16, 2023
2answers
Whirlpool microwave stove top light will not shut off after replacing burnt out bulb. Can I reset microwave somehow, or do I need a new control board for model no. WMH31017AB3?
DO NOT USE LED BULB <https://producthelp.whirlpool.com/Cooking/Microwaves/Microwave_Product_Information/Replacing_the_Cooktop_Light_on_an_Over_the_Range_Microwave>
12/31/2022 8:28:15 PM • Whirlpool... • Answered on Dec 31, 2022
Can I replace the door seal on my Whirlpool Integrated Microwave?
Gaskets are available, but with all microwave repairs, I would recommend using a repair technician unless you are confident of doing it properly. The door should be checked after all repairs for microwave leakage. https://www.repairclinic.com/Shop-For-Parts/a6b5c21/Whirlpool-Microwave-Gasket-Seal-Parts https://www.google.com/search?q=whirlpool+amw505ix+microwave+door+seal+replacement ..
11/29/2022 5:21:54 PM • Whirlpool... • Answered on Nov 29, 2022
How do you replace a Whirlpool microwave board please?
You don't. It is not a home repair job. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
11/22/2022 2:59:46 AM • Whirlpool... • Answered on Nov 22, 2022
Whirlpool GH7145XF Microwave Oven from 2002, 21 years!
I would suspect bad connection feeding the magnetron.
10/19/2022 6:49:33 AM • Whirlpool... • Answered on Oct 19, 2022
Whirlpool MT4070SK 700 Watts Microwave Oven Logo
12 questions posted
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Microwave Ovens
Most Popular Question
stuck microwave door
  • Microwave Ovens
