If you need a subsidy password, get it from your network provider or you may get it from online providers like Mobileunlocksolutions.com .They will help you to unlock your mobile easily..
You can unlock your mobile yourself at home to unlock your Motorola model mobile using codes are the best way , why i am saying codes means to unlock your mobile with codes are simple & easy way, Get the unlock code from this site www.classicunlocking.com/motorola-v557/rs17wp9,it has the best instructions and simple ways to unlock your mobile from the network lock..........If you unlock your phone using the unlock code then your phone gets permanently unlocked....After that, you can use it with any other network's sim card...........
there is nothing wrong with your screen, the problem is
from the flex that connects your screen to the phone's main board. This
flex must have worn out that's why your screen is not displaying any
picture.
The problem is common with flip and slide phones. The
flex gets worn out as a result of constant opening and close of the
flip or slide phone.
I would urge you to replace the flex and I
am assuring you that your screen will display picture again. You might
also be lucky to find out that the flex is not well fix, that is, it
may have loosed contact.
If you cannot change the flex yourself,
maybe you should take the phone to a local repairer within your
vicinity, so that the flex can be fixed/replaced.
Did you dry
the phone completely? Sometimes there is water trapped inside. Here is the procedure to take out all moisture
trapped in the phone: Dry the phone, battery, any accessory, etc. with
cloth and wrap each piece, phone and accessories, in newspaper. Place
a few handfuls of rice into a plastic bag and then place the wrapped phone in
the bag with rice. The newspaper wrapping avoids direct contact of rice
with your phone because the dust from the rice can get into the small areas of the
phone. The newspaper and rice will absorb moisture. Leave it there (with the
bag open) at least 24 hrs.
You will need to unlock it again. You will need contact your service provider to get the subsidy unlock code to use your phone internationally or on another wireless carrier. They can walk you through how to enter the code in properly. It is free of charge.
The only way to unlock this phone is to contact your service provider as it requires special set of software and cables or you can also get it unlocked from www.unlockexpert.com
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
