20 Most Recent
Nokia 8800 Cellular Phone Questions & Answers
No network service
changing the chip removes the service provider registration
use the original sim card and it will work
Photo recovery
Have a ZTE SAVVY 750C that needs the initial programming done/ the unlock code. Where can I get this without going thru customer service?
I forgot my code that unlocks my metro pcs zte phone
You can try all zero's (Example: 000000, 0000). Now since your device already has a custom unlock code, more than likely you will need a customer service representative of MetroPcs to assist you, where such information can be accessed.
Nokia 8800 strip problem
aslaam alaikum
my nokia 8800 problem is that its strip not working manually i also check it to nokia care centre **** nothing is possible so what i can do wth this mobile can u give me advice>>>??
When I call someone, they
Welcome to Fixya. Can you please tell me is this happening to all your calls? How about if someone calls you is it the same problem? Have you tried using a headset and see if you have the same issue? Please provide the information needed so that we can provide you a solution with your problem.
Thanks
My phone: Nokia 8800.
always ask
It's not the phone per se, it's actually the SIM card. Your SIM card is asking for the PUK code because it has reached the maximum allowable amount of SIM code tries. If you bought a pre-paid kit the PUK code usually is provided in the package, better yet if you're on a post-paid line the PUK code will be provided by your carrier.
Hope this helps!
Nokia 8800. i havent used
Please Visit your nearest Nokia Service Center(Nokia Care) They will unlock your Mobile.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up & Testimonials //
My crazy wife throw her
Sir , what they said is rite , Because alarms requirement for the battery voltage is very low compared to the network usage batter power requirement . So kindly replace the battery and check for the same . The system initially checks if there is enough power for starting up when the reply is no , it doesnt start . This initial checkup is byepassed during alarm activation .
Also there could be a possibility that the system software mustve been got malfunctioned or changed, so reinstall the system os ,
Thank you
