20 Most Recent
LG F9100 Cellular Phone Questions & Answers
Restriction code
hi restriction codes is nothing but the mobile is restricted to
particular network to solve the problem we can use codes to unlock .you
can get the codes from here
theunlockarena to unlock your lg f9100 mobile here they askthe
imei number of the mobile .finally they will send the codes to unlock
the mobile.once you entered the codes in your mobile your mobile get
unlocked and it will be free to accept any network sim.
12/10/2011 11:34:58 AM •
LG F9100...
Answered
on Dec 10, 2011
Restricted code
hi restriction codes is nothing but the mobile is restricted to particular network to solve the problem we can use codes to unlock .you can get the codes from here
unlocking4u to unlock your lg f9100 mobile here they askthe imei number of the mobile .finally they will send the codes to unlock the mobile.once you entered the codes in your mobile your mobile get unlocked and it will be free to accept any network sim.
11/24/2011 9:47:02 AM •
LG F9100...
Answered
on Nov 24, 2011
Unlock codes
I have an LG9100, After I make one call a little red arrow appears on the screen and will not let me make another call. It says "Try again later" If I turn off the phone, it works for one call when I turn it back on.
7/10/2010 2:40:33 PM •
LG F9100...
Answered
on Jul 10, 2010
Please help me
you have to buy a micro sd chip then load the songs, im just trying to figure out how to put the songs on, but you can buy a micro sd chip at zellers in canada for 20.00 easily!
2/22/2009 2:04:25 AM •
LG F9100...
Answered
on Feb 22, 2009
Blue screen
9 out of 10 is the Flex cable or LCD.
Just need to have a tech take a look @ it, but i had the same issue and it was the flex cable that connects the LCD to the Main board. And i think i have the flexes for this type of phones. but no business is allowed here i think.
5/25/2008 3:21:16 PM •
LG F9100...
Answered
on May 25, 2008
Not able to get on the internet
if you ring up your service provider they will send you the setting by text message if this still dont work then they can talk you through the setting s manually but the text should set the phone up for you worked with mine hope this is some help
11/25/2007 1:04:18 AM •
LG F9100...
Answered
on Nov 25, 2007
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
