Unfortunately, there does not seem to be any truly 'universal' remotes and we have two that won't 'learn' from the originals either.
They should be called 'multibrand' remotes.
Use your Vizio model number of your set and try here:
Remotes
This seems to be the best site but they are also not infallible.
Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
These are the general setup proceedings to universal remote controls. If you wish to get more programming procedures, check this link.
RCA 4-DEVICE
Remote Control know i need help how to program in my Toshiba TV can someone give me the code and the instruction by steps i will be thank you
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE. http://www.tvcodes.com/ may have the code for you.
Please check & ensure the infrared is emiting from the remote control. Though we cant see this infared beam with bare eyes, i found a trick to do so in http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html Replace the batteries when the infrared beam has weakened. If no infrared emited at all, then the electronic board should be replaced.
