20 Most Recent
Nokia 5500 Sport Cellular Phone Questions & Answers
How do i put a code on phone?
Do you want to put carrier unlock code in to your Nokia 5500 sport ? Do you have unlock code ? Do you need unlocking process to unlock your phone from sim lock ? If so, get free unlocking instructions from
Unlock-Zone.com to unlock it . If the code what you had already is not working , then get unlock code from the above provider to unlock your Nokia .
Lock code unlock
There is no master key to open all locks. Please recharge the battery fully and connect it to your computer running Nokia PC Suite. Re-install the firmware.
Hi dear my cell phone
Your phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
My Nokia 5500 sport is
If the keyboard is on but the screen isn't the screen is likely faulty.
You will need to have the phone either repaired or replaced. If you go for the repair option, a local dealer will do it cheaper!
Whats the unlocking code for a nokia 5500 its
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Nokia 5500 Sport
Try using a cover over the phone, n if u havent bought it yet then buy a version that wat made after march ( like sm1 suggested) apparently the problem was fixed after that.
Sim card rejected
You need to unlock handset first.
Visit http://www.unlock-free.com
Good luck.
My nokia 5530 freezes when starting
Try doing a master reset or a reset settings if possible. If this doesn't work and there is no physical or liquid damage to the phone than you need to contact your provider about a replacement because this is a device issue.
My mobile phone previously played jar but when i
I think you need to take it back to the nokia shop, its like the new software installed was not well, or maybe some files missing.
I believe your problem can be solved in the nokia shop.
Or have you tried using another jar file? Maybe the one you installed is corrupt.
I wish you the best.
Take care.
