20 Most Recent
Sony Ericsson Z550i Cellular Phone Questions & Answers
GPRS
the gprs connection will be activated only to phones which support it.please contact your service provider
Unlock protection code
http://www.mobile2mobile.net/unlock/menu_remote_unlock.htm (for all models)
please go on this site and unlock ur phone
Not charging
Hello My Dear Friend::::::::::"First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
I want to recover deleted pictures from my cell
You may try asoftech photo recovery which helped me before. You can download trial for free
http://www.asoftech.com/apr/Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Reset
try removing your battery for about 10-20minutes. reinsert it and turn on the phone. it may work
How to get internet connected to mobile
first,contact your network's customer care.tell them to send settings to your phone.save the settings and you will be able to reach to the internet.don't forget to create your account
Virus
You must install manual any anti virus protuction ... and then scan ur divice agains same problem na flashing ur divce
Z550i format code
Hi ,
To format ur mobile , Do the following steps
Select Menu >Settings >General>master reset then select continue
NOTE : Take a back up of ur contacts and other important data . All the files that u have stored in ur phone memory will be formated .
For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Says sim card full and it isnt
YOU NEED TO CONNECT YOUR PHONE A COMPUTER, AND HAVE IT DELETE THE FILES FROM YOUR SIM TO YOUR COMPUTER. OR REMOVED YOUR SIM FORM YOUR PHONE AND REINSERT BACK AND HAVE A TRY AND SEE THE PROBLEM BEING SOLVE, IF NOT YOUR HAVE TO BRING YOUR PHONE TO A QUALIFY TECHNICIAN AND HAVE IT SOLVE THE PROBLEM.
Charging solution
