20 Most Recent
Whirlpool GH7145XF Microwave Oven Questions & Answers
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
10/24/2013 6:26:08 AM •
Whirlpool...
Answered
on Oct 24, 2013
Whirlpool Microwave (Magi-cook) Problem
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
If you need further assistance, please feel free to contact me directly through the links at our site: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
7/20/2013 11:59:01 PM •
Whirlpool...
Answered
on Jul 20, 2013
Microwave builtin
This is almost certainly a bad upper door switch or a broken switch mount.
You can find exploded views for this model at http://tinyurl.com/gv383
The involved parts are on exploded view 5 with reference numbers 10, 11, 12 & 13.
We have important safety info, disassembly info, and door switch diagnosis and replacement info at our site which is available via our FixYa listing: http://tinyurl.com/yzjozk
7/20/2013 11:40:13 PM •
Whirlpool...
Answered
on Jul 20, 2013
Not heating but everything elseworks
possible and common reasons/parts are:
Diode most units use, typical one.
AC filter cap, style will vary but fairly round and of good size, usually buldged if bad but can be tested.Below is Magnetron which usually connects to the inverter board that switches it on etc.
12/18/2012 2:30:22 PM •
Whirlpool...
Answered
on Dec 18, 2012
Our home lost power yesterday, now microwave will
You should be sure that you leave the breaker off for about 15-30 seconds when doing a reset.If it still won't work right, you either have a defective board or a shorting keypad.Try the rest several times and note whether the display comes up that same way every time or what.We can help you with a repair either way.
Details of our service are at
our Web site, along with a video showing how to remove a typical
over the range control panel assembly in under 5 minutes.Feel free to contact me directly with your brand, full model number and symptoms.
We're
happy to help you with free advice and we'd appreciate your thoughtful
8/22/2012 12:42:53 PM •
Whirlpool...
Answered
on Aug 22, 2012
How old is my Whirlpool
The date on these is on the sticker. open door and look at the bottom left.. most were made in 2002
8/4/2011 2:12:35 PM •
Whirlpool...
Answered
on Aug 04, 2011
