20 Most Recent
LG HBM-710 Wireless Headset Questions & Answers
Can't remember how to pair
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
My headset will not pair with my new cell phone
First, open the phone's Bluetooth screen. On the HBM-710, press and hold the button on the face for about five seconds, or until the light comes on and STAYS on. Now find the headset with your phone and pair it.
Hope this helps!
710 motorola passkey
The passkey for Motorola H710 is
0000 (four zeros)
For more details, download the manual in PDF format by clicking this
link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from:
http://get.adobe.com/reader/
Thanks for using
FixYa.
Need passkey
Try 0000 as it is the default passkey for most devices.
Cannot place LG-HBM-710 in discoverable mode
It sounds as if the device is not paired with your Chocolate. Press and hold the button on the face of the HBM-710 headset for approximately five seconds, or until the light comes on and stays on steadily, then discover the device with your handset's Bluetooth screen. Once it shows up in the list of devices, select in and pair it with your phone.
How is it turned on
Press and hold button on face of device for approximately three seconds. Light should begin to flash.
To pair this headset, press same button for approximately five seconds until light comes on and stays on. Locate the device using your handset/phone's Bluetooth operation.
Headset
you haveto have the bluetooth connectivity serch for th device. one the device is found then your phone can be linked to that bluetooth adapter.
