Jsh digital safe i aquired an older model and cant get it to power up how do i power up this safe, does it take battaries
If you have an older model Jsh digital safe, you may need to power it up in order to use it. To do this, you will need to locate the power cord and plug it into an outlet. Once the safe is plugged in, you should see a green light on the control panel.
If the safe does not power up, you may need to troubleshoot it. If your Jsh digital safe won't power up, the first thing you should do is check the power cord. Make sure that it is plugged into an outlet and that the outlet is working.
If the cord is plugged in and the outlet is working, the next thing you should check is the control panel. Make sure that the power switch is in the ON position. If the power switch is in the OFF position, the safe will not power up.
If the power cord is plugged in and the outlet is working, but the safe still won't power up, there may be a problem with the control panel. The control panel may be faulty or there may be a loose connection.
To troubleshoot this problem, you will need to open up the control panel and check the connections. If you have checked the power cord, the outlet, and the control panel, and the safe still won't power up, there may be a problem with the battery.
The battery may be dead or there may be a loose connection. To troubleshoot this problem, you will need to open up the control panel and check the connections.
If you have checked the power cord, the outlet, the control panel, and the battery, and the safe still won't power up, there may be a problem with the safe itself.
The safe may be damaged or there may be a loose connection. To troubleshoot this problem, you will need to contact a Jsh digital safe technician.
11/22/2022 10:47:31 AM •
Power Up...
Answered
on Nov 22, 2022
