20 Most Recent
Edimax EW-7206APg (EW7206APG) 802.11b/g Wireless Access Point Questions & Answers
I cannot reset my Edimax
First turn on the access point then press RESET/WPs button for 10 seconds then all settings defaults.
Connect your router to computer with ethernet cable then you can access
it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If
you are not able to access it with above ip then check your computers
ip address gateway ip is your router ip try with it.
Then it ask for
user name and password.
Type user as "admin" and password as "admin"
or "password" or blank.
Then you can see configuration page of
router.
Click on wireless settings enable wireless then WEP
Security then add WEP code .It is your password to connect wi fi.Then
save settings and restart router.If you are able to see password in * or
# then you need o add new password but if you are able to read it then
note down it then you can connect with it.
If you are not able to
access router with above ip and user password then press RESET button
for 10 seconds it is in back side of router.
Then you can access it
with above method.
Let me know if you need further assistance.
Thanks
for using FixYa.
3/20/2018 2:21:34 PM •
Edimax...
Answered
on Mar 20, 2018
I forgot my password
you can reset the router to factory default by pressing the Reset button at the back of EW-7206APg for 15 seconds. This will erase all the setting in EW-7206APg and restore the factory default. after that
- Open Internet Explorer, at the address bar, type http://192.168.2.1 and press Enter.
- It prompts for username and password.
- The default username is admin. The password is 1234. Click on Login. You will get the configuration page of the EW-7206APG.setup new password
5/23/2013 1:05:05 PM •
Edimax...
Answered
on May 23, 2013
I can't log in cause
There is a hole behind your wireless access point that has a reset button inside of it, push it with a pen or something similar that can fit into the hole and hold it in there for a few seconds. The access point will now reset default configuration, and you will be able to set the access point up from scratch.
3/21/2011 7:33:45 PM •
Edimax...
Answered
on Mar 21, 2011
Cannot remember my wep number
You have to look in the routers set-up utility to find it
Open INTERNET EXPLORER and. In the URL address field, enter the IP address for your wireless router ( the DEFAULT GATEWAY. This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.do not type "www" just the number ( or check in IPCONFIG)
Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to routerpasswords.com and find the brand and model of your router. This site lists the default login information for most wireless routers you can try "ADMIN" or "GUEST" for user name and "PASSWORD" or "1234" or none at all for passsword.
You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords aka WEP key, WPA key, passphrase etc.
1/11/2011 5:40:23 PM •
Edimax...
Answered
on Jan 11, 2011
Driver CD Missing Pls Send
Hi bdo,
you can find a downloadable driver for your access point at this site:
http://www.nodevice.com/driver/EW-7206APg/get47394.html
Hope it helps!
Sky_Signal
10/30/2010 6:04:53 AM •
Edimax...
Answered
on Oct 30, 2010
How can i set password
log in to your router ( with an ethernet cable attached)
type 192.168.2.1 into your browser.
Default log in details are
admin / 1234
click on security, choose WPA2 (TKIP), choose a password and then save and exit
Now remove the ethernet cable and connect wirelessly, put your password in and you should now be connected.
8/31/2010 12:39:35 PM •
Edimax...
Answered
on Aug 31, 2010
Slow internet download speed from my edimax ew 7206 access point
You dont say what internet access technology you are using - DSL, Cable Modem, satellite, etc.
It is possible that your aggregate speed is being throttled by excessive traffic somewhere ELSE in the network and it may have nothing to do with the link from you access point. When you reset it, it may attempt to operate at the maximum speed only to be throttled by some other choke point in the network.
When you reconnect and get the 4-5 speed, how long does it last? Can you actually see the difference in performance? Most people cant tell the difference unless they are downloading large files.
3/13/2010 6:57:10 AM •
Edimax...
Answered
on Mar 13, 2010
How to set up password for my edimax wireless
you want to secure wireless network.
is there any other computer connected to the router with the ethernet cable?
If not then you will need to connect the computer to the router with the cable.check the ip address on the computer.open the router set up page.
you will find the option to make it secured.
Click here for more info
12/3/2009 7:41:37 PM •
Edimax...
Answered
on Dec 03, 2009
Lost contact between PCs connected via AP
Set all the PC's to have a manual IP rather then using the DHCP from the router.
Also set the Gateway and Preferred DNS on the network cards to the routers IP (IE 192.168.0.1)
4/24/2008 10:30:03 AM •
Edimax...
Answered
on Apr 24, 2008
