20 Most Recent
Intel Celeron M 420 1.6GHz 533MHz 1MB (LF80538NE0251M) Questions & Answers
Need ethernet driver for intel celeron 420 vista
Drivers for Intel products are available from the Intel website
www.intel.com However this is a system level problem and so the drivers for your sound chips are most likely to be found on your computer manufacturer's website or you motherboard manufacturer's website, or if your sound card is external to the m/b, the sound card manufacturer's website. In any case you will need your operating system details.
15.April.2014
Blank screen
Check the cables are all connected properly. Replace the Ram.
Cant remember my user account password
Lost Windows password:
- Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode. XP only.
- Login as other user (if other user is available) and manage users. Must be an administrator.
- Reformat computer.
- Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
- Free software option would be Hirens Boot CD. This one is command prompt only. http://www.hirensbootcd.org/ Must follow instructions exactly.
1801 mirocode patch error
Hi, Thanks for using fixya.
If you have changed your processor lately then you need to update the BIOS file othewise known as flashing the BIOS. Contact your Motherboard manufactuer or computer support 800 number.
Terry
Audio Drivers for Intel(R) Celeron(R)
Go to there website anddownload with the following steep.
Just . CLICKHERE
Type model no on the searchoption
Choice the product (e.g.chipsets)>
Desktop chipsets/laptop board>
Choice chip no(e.g.865/945)>
Selects your OS from leftside (e.g. sp/vista/win 7)>
Click on driver >
Now look bottom the page, anddownload one after one.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Hope it will help you.
I need a video driver
You can try download the video drivers from the below mentioned link:
http://www.downloadatoz.com/driver/item_acer-aspire-3680-notebook-vga-package-windows-xp.html
Thanks and regards,
Anil.B.R
My PC's color quality shows only lowest 4 bit
Sounds like you need to install a video driver. If you have a video card separate from the mother board, look up the card and download drivers for it. Alternatively, you may be able to use the Windows Update tool to autodetect the driver.
If the video card is on the motherboard, look up the motherboard's model number on the manufacturer's website as they should have drivers there.
Finally, look back at the disks you got with your computer, often there is a "drivers disk" which you can reload the driver with.
Can i upgrade this with 1gb ram?
Hi again!
Yepp, you can upgrade it to 1GB memory
This is the spec of the memory on your 2055:
Memory
RAM Technology
DDR2 SDRAM
Max Supported RAM
1 GB
RAM Speed
533 MHz
Installed Cache Memory
1024 KB
Good luck
Nic
DONT forget tp RATE me
1 GB of RAM vs. 420 @ 1.6 GHz
Hi there
if you remove 1 of the old sticks and the go to a good local computer repair store and show them the stick and tell them what you are wanting to do,, they can get you the right 2 gb sticks that you are needing , Also rember that memory is not the only thing that will speed up the computer . alot of installed programs registry errors spyware viruses Also not doing basic computer maintenance I.E defrag and cookie/ history removal will tend to slow the computer dowm ok so make sure you do these things too best regards mike
