20 Most Recent Southern Telecom Emerson Bluetooth Headset Black Wireless Headset Questions & Answers
0answers
2answers
Can't pair to iphone 3g
Hi, the iPhone 3G definitely does work with bluetooth. In fact, I'm talking on a bluetooth headset with my iPhone 3G right now.
You have to put both your Southern Telecom Emerson Bluetooth Headsetand the iPhone in "pairing mode".
On your iPhone, click the Menu button, tap the Settings icon, tap the General icon, and then tap the Bluetooth icon. Make sure that 'Bluetooth' is set to "ON" and not "OFF". As long as you have this screen up, your iPhone is in pairing mode.
Turn your Southern Telecom Emerson Bluetooth Headset off and wait a few seconds. On your Southern Telecom Emerson Bluetooth Headset, press and hold and Answer/End button for Five Seconds, until a solid blue light comes on, which places the device in Bluetooth discoverable mode.
Now that both devices are 'discoverable', the Southern Telecom Emerson Bluetooth Headset will show up on that Bluetooth screen on your iPhone. Be patient as it might take a minute to appear. Tap on the Southern Telecom Emerson Bluetooth Headsetin the list on your iPhone, and then it will ask you for a passkey. The passkey is "0000" (without the quotes). After you enter the passkey, the Southern Telecom Emerson Bluetooth Headset will show up on the list with the word "Paired" next to it.
Now you're paired! Incoming calls will automatically be passed to your headset as long as your iPhone can find it nearby.
Good luck.
1/14/2017 3:13:44 AM • Southern Telecom... • Answered on Jan 14, 2017
0answers
Emerson bluetooth wireless mobile headset model #
im temping to conect my wireless head set to my phone and do not know how
4/13/2011 5:09:38 PM • Southern Telecom... • Answered on Apr 13, 2011
2answers
If there is a battery in the earpiece; is it safe?
Yes it is perfectly safe. The easiest way to identify whether a bluetooth set is malfunctioning or unsafe is - HEAT. Normally batteries which are about to die or devices malfunctioning will heat up quickly when you charge it.
So unless you dont feel abnormal heat.. they are perfectly safe. Try to remove the BT earpiece when not needed. Your ear canal needs natural air flow. Blocking it with a prolonged use of a BT device could heat up the ear canal. That's where the problem starts! :-)
3/5/2011 4:11:28 PM • Southern Telecom... • Answered on Mar 05, 2011
How can i pair my em288 with my iphone
activate bluetooth option for iphone
3/3/2011 12:45:21 AM • Southern Telecom... • Answered on Mar 03, 2011
I forgot my pairing request
try 0000
2/28/2011 9:21:38 PM • Southern Telecom... • Answered on Feb 28, 2011
IT WON'T PAIR UP WITH
To pair a blue tooth device to a cell phone you first have to put the blue tooth power in the phone menu to on,then you must put the blue tooth device to discovery mode,to do this you hold down the power button while turning your blue tooth device on for6 to 10 seconds,there should be a silod light on the device,then in your phone menu you can add or search new device they should pair if everything is right,then it will ask for a pin pairing code .Most manufactures use a 4 digit factory code they are as follows 0000,1234,1111 or 9999,once your code is entered it will connect to the device,i hope this helps
2/22/2011 8:15:32 AM • Southern Telecom... • Answered on Feb 22, 2011
I have a samsung behold
hello ,now most blue tooth devices have to be put into a discovery mode,if you dont have your owners manual to follow the procuders most of the time you just hold the power button while turning the bt device on for 6 to 10 seconds and that turns it into discovery mode usually a solid light is on then when the device is found it will ask for a pin or pairing code,this is a 4 digit code,most manufactures use the following codes,0000,1234,9999,1111, hope this helps you out.
2/22/2011 6:12:37 AM • Southern Telecom... • Answered on Feb 22, 2011
2answers
Pass Key to EM228 bluetooth?
"0000" is the passcode for most of the Bluetooth headsets.
2/2/2011 2:07:44 AM • Southern Telecom... • Answered on Feb 02, 2011
2answers
What is the passcode of
I couldn't find any informations about EM228, but if you've meant EM227 instead, the pairing code is '0000' (four zeros).. If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards,
Carlos
1/27/2011 12:27:46 AM • Southern Telecom... • Answered on Jan 27, 2011
Will this device match up
There is no way such devices would pair with your ipod touch. It is only a few of such devices that can pair up with the ipod touch due to apple's strict security and procedures.
1/26/2011 11:19:06 PM • Southern Telecom... • Answered on Jan 26, 2011
Southern Telecom Emerson Bluetooth Headset Black Wireless Headset Logo
68 questions posted
Top Southern Telecom Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Southern Telecom Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Southern Telecom Radio Communications
Most Popular Question
battery in earpiece safe
  • Radio Communications
