Hi
Check to see that the refrigerator has power and is working. Reset or replace the fuse or circuit breaker in the house if needed, especially if a power outage has recently occurred. Make sure the water valve is connected to the refrigerator and is fully turned on. Ensure that the ice maker is turned on. Some Whirlpool refrigerator models have a switch located above the ice bin; some models have an arm that should be raised up to turn the ice maker on. The arm is also located above the ice bin. Clear away any ice cubes that may have gotten jammed in the ice maker, bin or dispenser that may be preventing ice cubes from moving as expected in the system. Use a plastic utensil to clear away any obstructions. Contact an authorized service center for assistance if the above steps do not fix the issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
51 questions posted
1,894 Questions
803 Questions
611 Questions
487 Questions
348 Questions
