20 Most Recent Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator GD25DFXF Questions & Answers
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
https://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
https://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
https://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Whirlpool 25.2... | Answered on Sep 10, 2011
depending on your model. if its just a reg, side by side, you more than likely need a relay/ overload which is located on the compressor,the relay only works after it cools down. unplug ref from wall, remove rear cover to see and touch compressor to see if it starts when you plug back in to the wall. if it doesnt start in three attempts. replace it. easy way to diagnose..
Whirlpool 25.2... | Answered on Jan 17, 2011
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Whirlpool 25.2... | Answered on Jan 04, 2011
When an ice maker stops making ice usually the problem is not the ice maker. More often than not there is ice build up on the evaporator coils due to an automatic defrosting problem.
Other times the fill tube freezes up. Item #2:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251398&diagram_id=99075#d99075
Expanded view:
http://www.appliancepartspros.com/part_details.aspx?part_id=2992967
Check the plastic tubing on the back of your unit to see that it is still connected to this tube. If the plastic tubing has separated from the fitting the ice maker fitting has frozen solid internally with ice.
You can remove this tub by rotating it about 30 degrees and then pulling it out from the back if the unit. You may have to use a hair drier to defrost the tube.
This link will assist you in determining if there really is an ice maker problem:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
It is step by step info on how to cycle the ice maker and test it. The procedure calls for testing (jumpering) a live circuit so be safe.
I think your going to find that you have an automatic defrosting problem that is causing the freezer to warm up to the point that the ice maker thermostat has disabled the ice maker.
The defrost timer is here:
http://www.appliancepartspros.com/part_details.aspx?part_id=3110896
All parts for your Unit can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251398&diagram_id=99074#d99074
Thanks for using FixYa.
Kelly
Whirlpool 25.2... | Answered on Jun 13, 2010
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
https://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
https://www.fixya.com/support/r3885294-refrigerator_troubleshooting
https://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Whirlpool 25.2... | Answered on May 24, 2010
There may be several reasons for this like a leaking water control valve, air in water lines or you may just need to replace the dispenser water line with a kit Part Number 8201537 Try unplugging the dispenser power on rear of refrigerator and tell me if that stops the flow. let me know, Sea Breeze
Whirlpool 25.2... | Answered on Apr 21, 2010
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
https://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Whirlpool 25.2... | Answered on Apr 20, 2010
Hi
I have problems with whirlpool refrigerant the compressor not working no any electric power came to it that for I checked all the ather thing it's ok and the out fan behind the compressor it usually working.
My question is what the main thing to make compressor not working in the same time fan are working.
Whirlpool... | Answered on Oct 17, 2019
In the freezer compartment there is a panel on the ceiling of the freezer, remove this with a small spatula, it snaps off, there is a dial that controls the airflow on the panel, inside this panel is the defrost control board, it does not use the old time defrost timer, it uses this part, its about $250
Cntrl-Elec Part Number: AP6023580 Made by: Genuine Whirlpool part OUR PRICE $259.12 REGULARLY YOU SAVE $260.53 $1.41
Whirlpool... | Answered on Oct 16, 2019
Refrigerators Logo
13 questions posted
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
ed25pqxdw01 whirlpool refrigerator both
  • Refrigerators
