20 Most Recent
Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax Questions & Answers
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
- Overheating
- Wrong Paper Type
- Printing Labels
- Cracked or Dirty Rollers
- Use of Wrong Tray
- Incorrect Loading of Paper
- Paper Overload
All in one center not working
Please visit the Lexmark website to download and install the
Lexmark X4270 Printer Driver on your computer. Select your operating system
> click on "FILTER" > click on the driver under Recommended
Downloads > download and execute the file. Simply follow the instructions on
your computer screen to complete the installation.
Fax will not work--no dial
Make sure your phone line for the fax is correctly plugged into the Line Port of the printer and not the EXT port. For a more comprehensive guide on how to setup the Lexmark X4270 for faxing, please refer to the
Lexmark X4200 Series User's Guide.
The user's guide also contains some fax troubleshooting steps for your reference.
If you still need assistance, please contact Lexmark Technical Support Center.
Black line on scanned copy
If you notice poor image quality in scans, faxes, or copies, you may need to clean the scan lens and the white roller.
- Unplug the power cord from the wall.
- Open the control panel.
- Pull the roller lever forward, and then lift the white roller out of the All-In-One. Note: The scan lens is located under the white roller.
- Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
- Reinstall the white roller.
Where do we push to
Press Black or Color button (whichever you prefer) to start sending the fax. Thanks.
Lexmarkx4270 read erro 1203 check manul what the
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Normal
0
false
false
false
font-size:10.0pt;
Power off the AIO and remove the power supply from the back of the
unit. Wait 30 seconds, then reinsert the power supply, and power the AIO
on.
Did the error message return?
Yes: Continue to step 2.
ue to Step 4.
Cannot download scanner i have
Hi
You can download driver from below link.
Click here
Download driver for winxp then install then you can see scanner icon in my computer open it then you can scan documents with that wizard.
Let me know if you need further assistance.
Thanks for using FixYa.
Aiocexe not working-x4270 lexmark -all in one not
The aioc.exe may be corrupted and needs to be repaired or reinstalled. You will need the installation cd to repair the software. Just insert the cd in the computer to repair it. You can also use the software online. Just click on this link:
http://bit.ly/a2Odsv . Download and install the software. If that won't resolve it, you might need to uninstall everything by going to Start Menu > All Programs/Programs> Lexmark Series folder> Tools> Uninstall. Restart pc. Reinstall the software.
