20 Most Recent 2wire 1800HG Router (RG1800HG00) Questions & Answers
0answers
2wire 1800hg random no internet/random access, repair/wait fixes
It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
6/3/2014 6:10:53 AM • 2wire 1800HG... • Answered on Jun 03, 2014
Windows 7 driver
No driver needed since it does not need to be installed into Windows. Connect the ISP modem to the main port. DSL or Network port, depending on your service. Then connect your PC to any other port. That's it!.To adminstrate. Open a web browser and go to 192.168.1.254 Alternate Admin URL: http://gateway.2wire.net/setup/There is a small reset hole if it already has a password. Hold it in till it cycles. This will clear any custom settings/http://support.2wire.com/http://www.2wire.com/pages/pdfs/106.pdf
10/22/2012 5:38:18 AM • 2wire 1800HG... • Answered on Oct 22, 2012
2WIRE 1800hg wont allow UPnP device to connect
TRY THIS AT http://support.2wire.com/?page=view&article=133&text=Sony%20streaming%20media%20player&cat=&sort=
1/13/2012 1:29:51 AM • 2wire 1800HG... • Answered on Jan 13, 2012
How can i set up
your 2wire 1800HG modem has the cd-less install or Greenlight technology in it. it will automatically startup once you open a browser, (preferably IE. However, if you don't see it, try pushing the reset button at the back of the unit for 30 sec. open IE, then you will see the installation page.
NOTE: make sure you know what your username and password is... for authentication purpose...
9/3/2011 4:54:03 AM • 2wire 1800HG... • Answered on Sep 03, 2011
Does the 2wire 1800HG work
The answer is yes...
Thank you!
7/11/2011 1:46:11 AM • 2wire 1800HG... • Answered on Jul 11, 2011
I am trying to connect to the internet using my
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
1/20/2011 12:51:52 AM • 2wire 1800HG... • Answered on Jan 20, 2011
No lights. no power. does not work at all.
try to change your power adapter. if still no result - yes - it's dead
1/10/2011 2:35:14 PM • 2wire 1800HG... • Answered on Jan 10, 2011
Im getting a red solid
Try to reset your router, you are not supposed to be getting a red light. have you computer off to while you re-set it, then turn it back on.
12/22/2010 3:39:44 AM • 2wire 1800HG... • Answered on Dec 22, 2010
What are the power requirements for this modem - I
My 2Wire 1800hg original power transformer shows OUTPUT of 6V (Volt) and 2000ma. (The 2000ma is also known as 2amp, like 24 inches is also known as 2 feet). On polarity the inside hole is positive (+).
11/11/2010 5:53:12 PM • 2wire 1800HG... • Answered on Nov 11, 2010
2wire 1800HG Router (RG1800HG00) Logo
146 questions posted
Top 2wire Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • 2wire Computers & Internet
Most Popular Question
windows 7 driver
  • Computers & Internet
