20 Most Recent
Sony VAIO VGN-N220E/W Notebook Questions & Answers
Vram is 256 mb but dedicated is 64 mb and shared
You should not change this. Laptops have small video chips and often depend on "shared" memory to achieve good performance without overheating. Basically, the video processor borrows some of your installed RAM memory. Also, your laptop may have been supplied to you with less total RAM memory than the maximum and you can add more memory. In Windows, click on Start then right-click on Computer and select Properties. In the Properties window you can read how much total memory is installed. 2GB (2048MB) is a desrirable amount for Windows XP. Windows Vista and Windows 7 can benefit by having total 4GB of RAM memory. Check your Sony user manual for instructions on adding more memory. Basically, you turn off the laptop, remove the battery pack and unscrew a small cover on the bottom of the laptop to access the memory slots. Usually, there are 2 slots here. Ideally, you should install a matched pair of memory modules (a "kit") for peak performance. However, quantity of memory is more important than having matched modules, so if one slot is occupied and the other slot is empty you may simply buy one more module and install it in the empty slot.
2/2/2015 8:45:58 PM •
Sony VAIO...
Answered
on Feb 02, 2015
WLAN light is off
The light indicates that the radio for wireless internet access has been turned off. On my Sony the light is on the right hand side nearest me. It is green in color. The on off switch is on the left hand side next to the headphone and microphone jack. Yours may be different but somewhere is an on off slide switch. So explore the sides and back till it is located
1/14/2012 2:34:50 AM •
Sony VAIO...
Answered
on Jan 14, 2012
I have a Sony Vaio
There are many ways to connect your Vaio to a Bravia. If you have a router, you can connect both pc's to it using ethernet cable (cable that looks like a telephone cord but a little bigger). Then open your control panel and click on networking. then follow the prompt to create a home network to allow both pc's to share files.
You can also connect to the Bravia using remote desktop through the internet. The easiest way to do it is to open the internet and type in join.me.com in your search box to locate their website. Then open it. You will see "share" on the left side in orange. Click on the orange arrow. The site will install a small file and then give you a nine digit number on the top of your screen. Have the other computer go to the same website but instead of clicking on "share" you click on "join" on the right side in green instead and then enter the nine digit number into the box and press your enter key on your keyboard.
You should be able to see the Bravia's computer screen. If you want to control the Bravia computer using your Vaio, click on the picture of the mouse at the top of the screen while in join.me and it will send a request for permission to the Bravia to control the mouse and access the files on it. The Bravia approves the request and then you can move and control their mouse.
9/22/2011 6:48:39 AM •
Sony VAIO...
Answered
on Sep 22, 2011
How do i remove the hard drive?
Had the same issue, couldn't find a solution on-line, but I figured it out. First remove the battery and the screws underneath it. Then remove all the screws on the bottom of the laptop. Remove the optical device and remove the 2 or 3 screws holding the bezel to the base.
Here's where it gets tricky. There is one more screw under the keyboard, right where the F6 key is. Can't get to it until you remove the keyboard, but there is no obvious way to remove the keyboard.
Pry the case apart a bit and look inside, there are two plastic release cllips that hold the keyboard in. Very carefully retract these clips and remove the keyboard. Then you'll see that last screw. Take it out and you can slide the top bezel out of the way without removing the touchpad cable.
Replace the hard drive and put it all back together.
Hope this helps
Stillwater Computer
4/6/2010 4:10:11 PM •
Sony VAIO...
Answered
on Apr 06, 2010
Microsoft office 07 product key
If you
have previously registered the software or have a proof of
purchase for the software, contact the manufacturer and they
will provide you with a new product key.
FixYa and it's experts
do not provide product keys, serial numbers, illegal software,
authorization numbers or codes, warez, hacks or cracks under any
circumstances. Any expert that does so will be barred from answering
questions. Those asking are subject to their membership being deleted
and be barred from the site.
Thanks
for using fixya
Regards
PCmania
4/5/2010 9:15:22 AM •
Sony VAIO...
Answered
on Apr 05, 2010
I need to remove the hard disk and to replace it
most sony laptops either have the hard drive internal and either access is via a back plate with a few screws underneith or you have to undo all bottom screws then were the track pad is the top borrom half with either come away reveling the hard disk or the complete bottom will come away.
2/11/2010 9:20:09 PM •
Sony VAIO...
Answered
on Feb 11, 2010
Battery shows full charge, but when unplugged
Battery most likely has dead cells, the live cell that is still working is showing 100% but does not enough juice to keep the computer running by itself. You need a new battery.
1/7/2010 12:39:58 AM •
Sony VAIO...
Answered
on Jan 07, 2010
CD-DVD drive doesn't work
they do make ****, and its expensive to replace any of thier parts...you have to replace it, but if you search by make of laptop usually you can find a comparable one for cheap. may be out of a different sony or a different brand but if its the same num it will work
9/2/2009 12:48:26 AM •
Sony VAIO...
Answered
on Sep 02, 2009
