20 Most Recent
Intel DG965RY Motherboard Questions & Answers
Processor fan start it self without indicate on
1. do you hear any beep from the computer, and which colour does the front LEDs indicate green or red? does any of the keyboard leds blink?2. the automatic switching on is not a big issue coz it might be caused by the improper bios settings.there might be a faulty chipset on the motherboard. or you may have recently added another hardware that does not comply with the bios settings.contact through
[email protected] or +254724494089
Sir, I have Intel DG965RY
I had the same problem.After updating the audio driver front panel was not working..
then I just un-install the driver and install the old one given in the mother board disk. And it solved the problem.
You can try it.
I brought my intel pc
I brought my intel pc on 03/09/2007, core2 duo processor& dg965ry chipset mother board. Now my system get is not booting and showing some EB Display on the right end corner. plz find me the Solution...
Error code 10 intel r 82566 nic
The Intel Nic driver did not install correctly. Click on the link below to download the Nic driver. Create a new folder on you're desktop & give it a name. Save the Nic driver into that folder.
Number 4. Under Drivers. LAN: Intel® PRO Network Connections Driver. File name: LAN_allOS_13.0.1_PV_Intel_165622.exe. Run the .exe from within the folder.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2377&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Re-install the driver. If windows still fails to install correctly than install through device manager. Click on the start button, slide up to & open control panel. Open the System icon. Click the hardware tab, than click on the device manager button. Find the yellow ! point for the nic driver. Right click once on the ! point, than slide up to & left click update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away. Click the Browse button. Another window will open. (Browse for the folder you created on you're desktop).
Open that folder. Left click once on the new yellow folder named LAN_allOS_13.0.1_PV_Intel_165622 so it is high lighted, than click ok. Windows should correctly install the Nic driver. Restart you're system when finished. That's it!
Mike
Sir, My PC is starting
The UPS may not be sufficiently stable on power-on to run a PC immediately.
Try going into the BIOS setup after the restart and look for the option that has the computer "Start up automatically after power failure." Turn this off. That will take care of problem 1.
If this also takes care of problem 2, you may want to check whether the UPS has a problem. Start by plugging a couple of lamps with 100 Watt bulbs into the UPS outlets instead of the computer. Turn it on - the lamps should behave normally, not flicker or change brightness. With the lamps and UPS still on, unplug the UPS. The lamps should stay on with little or no change, and the battery warning light should not come on right away. If the UPS fails this test, its battery may need to be replaced or it has a regulator problem.
I have a DG965RY mother
Yes, you can install a Pentium dual core processor on this mother board. Below is a complete list of the compatible processors for this motherboard:
http://www.cpu-upgrade.com/mb-Intel/DG965RY.html
Windows 7 will also work with this motherboard. Just make sure that you install a minimum of 2GB RAM for you to take full advantage of Windows 7's Aero feature.
Card reader, nine in one, USB2.0, not connected.
Here is the Intel page that has all kinds of links for this board:
DG965RY Support
Look for the on ethat says Board Component Diagram.
Thanks for using Fixya.
PS. You might want to save that page to your favorites.
Also keep in mind if you go to the Intel home page, there is a link that will detect and update all your drivers automatically.
No display ? but when i remove the ram ,beep
If you have an onboard video card, there is probably a mistake. If not then try to replace the video card. It is possible that it also helps if not then you should let the technicians to test this motherboard.
USB ports power up but a window comes up saying
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
don
How do I reset my BIOS back to it original
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REMOVE OUR MOTHERBOARD BATTERY TO RESET YOUR BIOS
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
