20 Most Recent Acer Aspire 3050-1733 Notebook Questions & Answers
4answers
Dvd decoder
11/7/2019 1:32:35 AM • Acer Aspire... • Answered on Nov 07, 2019
2answers
PCI DRIVER
right click on the ? and uninstall it. Scan for hardware changes and let windows find the driver.
4/28/2019 10:45:32 AM • Acer Aspire... • Answered on Apr 28, 2019
3answers
Drivers for acer aspire 3050
There you go... hope it can help you.
http://cr.am/framed.php?url=http%3A%2F%2Fsupport.acer-euro.com%2Fdrivers%2Fnotebook%2Fas_3050.html&ref=driverguide
1/27/2015 3:43:48 AM • Acer Aspire... • Answered on Jan 27, 2015
The screw on the bathroom door has been strippped how do I get the door off
if you have a hardware store or a place where you buy tools go and buy a set of easy outs these will after screw is drilled out and then the tool is tapped onto the the hole drilled will bite and allow you to remove the screw
7/25/2014 4:50:39 PM • Acer Aspire... • Answered on Jul 25, 2014
Can't find the button to the wifi
button is placed down at left side mousepad on the edge just a little bit to left of headphone /speaker connectors
5/9/2014 2:42:25 PM • Acer Aspire... • Answered on May 09, 2014
Acer aspire 7715 will not boot
harddrive failure
5/5/2014 11:04:00 PM • Acer Aspire... • Answered on May 05, 2014
Bios password reset scer 3050
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
4/28/2014 11:39:03 PM • Acer Aspire... • Answered on Apr 28, 2014
0answers
My laptop wont boot unless i shake it it freezes
your hard drive is more than likely loose or could be on its way out I would back up all your important files (to another external drive) and then pull the hard drive also listen to the laptop and see if its clicking or whining
8/6/2013 4:03:30 PM • Acer Aspire... • Answered on Aug 06, 2013
11answers
Forgot windows password
Hi, why don't you remove the password with Windows Password Recovery 6.0? If you can’t remember the windows admin password, try to reset it with a reset disk. Free download windows password Recovery from http://www.recoverlostpassword.com/products/windowspasswordrecoery.html and there is a .iso file included. Burn the .ISO file onto a blank CD which is called windows password Recovery disk. With this disk, you can reset the unknown password without erasing anything5e4ff7b.gif
7/7/2013 7:12:07 PM • Acer Aspire... • Answered on Jul 07, 2013
I have an Acer Aspire 3050 and it only goes to a black screen that says "Operating system not found" Help Need this working again...
OK, best case scenario is your hard drive is corrupt, worst case, hard drive is dead.What to do - you could download the hirens boot cd and see if you can rejuvenate the hard drive firstly by going into mini windows and check if you can see the C: drive in windows explorer, if you can thern running chkdsk c: /f might sort it for you.There are other utilities in the hirens disc that could help but that's where I'd start.If you're not confident doing this then you might need to take it to your local pc engineer.
3/22/2013 9:40:14 PM • Acer Aspire... • Answered on Mar 22, 2013
2answers
Where are all the screws
Here is the service guide, it has the full disassembly in it. Go to page 65 and there are illustratyions of where all the screws go and their purpose.
http://tim.id.au/laptops/acer/aspire%205050%203050.pdf
9/14/2012 8:02:06 PM • Acer Aspire... • Answered on Sep 14, 2012
Opertating sytems not found
Its possible the drive may have gone bad.When booting, go into the bios (could be F1, DEL, F8, F10) if the drive is *not* showing up in the bios, then your drive is probably dead.You can pull the drive out, attach it to a mini dock and attach it to a desktop PC to see if the drive is recognized. Universal USB Dock at Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16817707192Can it be done cheaper? YES, But not as elegant ... still externally attaches with USB (has connectors for all types)http://www.newegg.com/Product/Product.aspx?Item=N82E16812156017and even cheaper if you open the PC and have an IDE controller to attach to (many new pc's don't have IDE any more when purchased from mass manufacturers like dell, hp, ibm, as they leave off the connectors on some systems for the few pennies it costs per machine)4 dollars: http://www.newegg.com/Product/Product.aspx?Item=N82E16812200053IF the drive is not recognized, you've lost the data and the technology exists to revive the drive but that's usually in the 1000 dollar range.If the drive is not recognized, you can buy a new replacement and put it in yourself .. then reload the operating system.Judge your costs accordingly .. if the drive is 200 dollars, you can just as easily buy a new replacement laptop (ok. 250 to 299 .. but still they are that cheap by comparison)
7/28/2012 2:50:52 PM • Acer Aspire... • Answered on Jul 28, 2012
3answers
Hi, I wanna reset my
my laptop operating system is vista ultimate
2/29/2012 7:00:37 AM • Acer Aspire... • Answered on Feb 29, 2012
Forgotton password
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
2/27/2012 7:44:55 AM • Acer Aspire... • Answered on Feb 27, 2012
How do i restore to factory settings
You will need the restore disk or a recovery partition on the hard drive.
2/1/2012 1:29:12 AM • Acer Aspire... • Answered on Feb 01, 2012
Acer Aspire 3050-1733 Notebook Logo
240 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
cursor slow reaction
  • Computers & Internet
