20 Most Recent Bosch Nexxt 500 WFMC3301 Front Load Washer Questions & Answers
4answers
How to use bosch wvf
Hi.
Here manual : BOSCH WVF2000 Washing Machine.PDF
Here parts manual : WVF 2000 Bosch-Spares.pdf
Regard
1/7/2023 11:57:23 AM • Bosch Nexxt 500... • Answered on Jan 07, 2023
2answers
Fabric softener dispenser fills up with clear water after
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
6/1/2022 3:09:08 AM • Bosch Nexxt 500... • Answered on Jun 01, 2022
Why doesn't the door open?
Door won't unlock
7/1/2019 9:14:59 PM • Bosch Nexxt 500... • Answered on Jul 01, 2019
2answers
Bosch washer won't spin with wet clothes
I am not sure if Bosch has a "load sensing" sensor, but I would start there else you may have a motor issue, or bad capacitor on your motor.
12/4/2017 5:08:56 PM • Bosch Nexxt 500... • Answered on Dec 04, 2017
Why does my boot keep tearing, original lasted years, all replacements are months.
had this once before A wire from an under wire bra found its way in-between the inner and outer drum every now and again it would find its way to the seal and tear it then one day the drum started making a loud grinding sound on further investigation we found the wire that fixed both problems
11/16/2017 11:31:11 AM • Bosch Nexxt 500... • Answered on Nov 16, 2017
0answers
My washer completes the cycle just fine but after I've removed the clothes, the tub slowly fills with water. This happens even when the machine is off. Is it a valve or drain problem?
well if theres more water in it now then when you took clothes out , id fail to se how its a drain issue , no id lean towards the inlet solenoid valve have a small bit of debris keeping it from closing all the way , this will probably need replacing
3/18/2016 1:46:40 AM • Bosch Nexxt 500... • Answered on Mar 18, 2016
Error E:01
The control board is seeing the door as open even though it may be closed. Here is how to repair it: http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-code-er%3a01/1
11/15/2015 1:38:18 AM • Bosch Nexxt 500... • Answered on Nov 15, 2015
Washer keeps saying error5
Water temperature sensor is defective and needs to be replaced. Here is how you repair it: http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-codes-er%3a05-and-er%3a06/2
11/15/2015 1:33:55 AM • Bosch Nexxt 500... • Answered on Nov 15, 2015
E01 error
The control board is seeing the door as open even though it may be closed. Here is how to repair: http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-code-er%3a01/1
11/15/2015 1:30:40 AM • Bosch Nexxt 500... • Answered on Nov 15, 2015
4answers
Error code E:01
Hi and welcome to Fixya, The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary. I'll watch for you to respond with the result's. Good luck. Macmarkus :)
11/15/2015 1:26:55 AM • Bosch Nexxt 500... • Answered on Nov 15, 2015
0answers
Door won't close on Bosch 500 washing machine
Door latching mechanism is bent out of position and needs to be realigned.
10/14/2015 7:56:47 PM • Bosch Nexxt 500... • Answered on Oct 14, 2015
Why is there still water in my bleach/fabric softener dispenser after cycle ends on Bosch WFMC5301UC/07
the soap dish area inside needs a good clean
8/21/2015 10:19:52 PM • Bosch Nexxt 500... • Answered on Aug 21, 2015
2answers
Door will not open bosch nexxt 500 series
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck.
The door typically locks as a result of the unit failing to drain, so....
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
**NOTE - you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan
Once the door is open and you've removed the items you wanted. Unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets".
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
8/9/2015 1:57:06 PM • Bosch Nexxt 500... • Answered on Aug 09, 2015
How can I fix my washer when it stops with an E13
E13 indicates your input voltage is to high also can happen with faulty motor/ brushes
7/12/2015 1:09:35 PM • Bosch Nexxt 500... • Answered on Jul 12, 2015
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
329 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
error code e 01
  • Washing Machines
