20 Most Recent
Nokia 3315 Cellular Phone Questions & Answers
I have an airtel mobile no. 9867451653 i am asked
PUK code is a SIM specific code assigned by your service provider. No way you can guess & enter it. So, when it asks for the PUK code, don’t do anything, get the PUK code from your service provider. Airtel has a easier way of getting PUK code. For getting PUK code of a Airtel number, send PUK<space>PhoneNumber to toll free number 121. You can make use of any other Airtel number to send this message since your SIM might have been blocked already.
If the above method doesn’t works or your service provider is not Airtel, call to customer care using any other mobile phone which uses the same service provider.
For More Details Visit This Page:-
Click HereHope this Helped!
Nokia 900
what kind of lock did you mean?
If it's network lock means,you can unlock your Nokia 900 phone by network unlock code.If you need an unlock code visit
MobileUnlockSolutions.com Here you can unlock your phone at low cost.
My airtel sim was blocked
When you enter a wrong pin number three times the phone asks you for a PUK number. The PUK code is generally eight digit number This PUK number is an unlocking code which helps you to unlock the phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to buy a new simcard. It might happen that your phone might ask you for PUK2 after you enter your PUK number. You can find the PUK code is in your SIM card documentation Starter Pack. If you do not have this then contact your phone service provider. Your cell phone service provider can give you the PUK code once they have confirmed your identity to prevent any stolen SIM access.
Nokia 3315 contact service error
i am the service and i am teling u that the phone shud ve a new firmware
get it to a repairshop and tell them i want to flash my phone they knw what to do after that sentece
9729429118 pleas tell me my puk no.my e-mail Id
Typically when a phone is asking for a PUK code it means you have tried to edit or set the secuirty pin code. Unfortunately these codes are already predefined by the sim card and the service provider. It gives you the sensation that you can set or change the code but you cannot. You get 3 attempts to enter the correct code after which the phone asks for a PUK code. When it asks for the PUK you also get three tries to undo it. Again PUK codes are predefined by the sim card and the service provider. If you call your service providers technical support number or customer service number they can provide you with the PUK or the PIN code.
>>>> Once the PUK has been entered in wrong 3 times the sim card is shot and deactivated. At this point you will need to get a new sim card to get your phone up and running again. If you have numbers stored to your sim card and not to your phone you will have lost them.
Contact service error 5130
Its problem with the connector located near the charging pin.1. disassemble it 2. clean all the connector pins and also the respective pin points on the motherboard, then reassemble it.
