20 Most Recent
Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Firewall Rou Router (TN-432BRP) Questions & Answers
Manual Setup of Trendnet Router
1. Open Internet Explorer 5.0 or above Internet browser.
2. Enter IP address http://192.168.10.1 (the factory-default IP address setting) to
the URL web address location.
3. When the following dialog box appears, enter the user name and password to
login to the main configuration window, the default username and password is “admin”.
8/20/2018 6:29:23 AM •
Trendware...
Answered
on Aug 20, 2018
HOW DO I CONNECT TO GET A SECURE WIRELESS CONNECTION
that is to access the configuration menus of the router. you mush login with a username and password, the configure the router to require a secure protocol... meaning any body connecting to your router is required to login with a password. The connect between the device and the router is secure. Beyond that (Router to Internet) read up on it! You could use a VPN,
8/21/2014 3:32:38 AM •
Trendware...
Answered
on Aug 21, 2014
Why do I keep losing internet connection?
your device is to far away from the router, your got to much material in the way blocking the signals, or you have some type of electrical signal interfering the wifi signals.
8/21/2014 3:10:55 AM •
Trendware...
Answered
on Aug 21, 2014
Security acces is different on the router i cannot connect to the router
LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usual be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware sestets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
4/13/2014 10:20:39 PM •
Trendware...
Answered
on Apr 13, 2014
My phone is interferring with my wireless internet
Wireless G operates at 2.4Ghz. Your wireless phone most likely uses this same 2.4Ghz frequency. If your phone has the option to change the frequency - then I would do that to see if it helps. If your phone will not let you change frequency, then you may need to purchase a new phone that doesn't operate in the 2.4Ghz range.
11/14/2011 6:06:50 PM •
Trendware...
Answered
on Nov 14, 2011
I purchased a wireless router
installing a network
requirmenst rj45 crimping tools and UTP cable
before u crimp the rj45 must fallow the color coding
white orange
orange
white green
creating a workgroup for file and printer sharing
visit this link for window xp
http://reviews.cnet.com/4520-11334_7-6232456-3.html
http://www.home-network-help.com/set-computer-name.html
for window 7
http://windows.microsoft.com/en-US/windows7/Join-or-create-a-workgroup
note all workgroup name should be same
ex.. (you computer1) computer "name is: com1" workgroup is: maywrkgroup"
( your computer 2) computer "name is: com2" workgroup is: maywrkgroup"
5/27/2011 12:30:14 PM •
Trendware...
Answered
on May 27, 2011
Were do i find the
If by pin you mean the KEY for wireless SSID then you have
Log in to the AP by connecting a PC with AP via wired cable.
Point to web address: http://192.168.1.1 and input user and pass (IP may change due to config)
Go to wireless->Security
Change the key in Passphrase and you are good to go..
3/12/2011 11:43:23 PM •
Trendware...
Answered
on Mar 12, 2011
How do i find the
For you to access your router you need to type 192.168.1.1 to he address bar of your browser and it will ask you for a username and password. The default username is "admin" and the default password is admin.
Thanks for using Fixya.
1/27/2011 4:24:18 PM •
Trendware...
Answered
on Jan 27, 2011
I HAVE AN IPOD TOUCH,
Depending on the version of your router (you can determine the version from the
Trendnet support web site), there may be a firmware update for your router that will resolve the issue that prevents your iPod Touch from connecting to it.
There has also been discussions that simply reseting the router by disconnecting the power cord for a minute or so can allow an iPod Touch to successfully associate with a flakey router.
12/27/2010 7:00:35 PM •
Trendware...
Answered
on Dec 27, 2010
Everything seems plugged in but
even if the cables are plugged in, this does not mean all is ok..
Have the cables checked with a network cable tester.
If you are using the wireless system to connect to an access point, check and make sure that no-one is using a cordless phone which operates on the same frequency as the wireless access point.
Most operate at around 2.4 ghz which is in the same area as the wireless signals.
Dont forget, anyone in the same general area (within 100meters) using a cordless phone can cause this issue.
You can also get drama's from other household appliances like microwaves, TV's or anything which uses large magnetic fields in normal operation..
If in doubt, switch these items off or change the position of yourself or the access point..
12/19/2010 6:08:02 AM •
Trendware...
Answered
on Dec 19, 2010
How do I change the
To change the channel, you need to loginto the router management page and click on the WLAN tab.
You can find the channel information under the WLAN tab. Change the channel ( channel 1 , 6 , 11 ) are the non overlapping channels and mostly prefered.
10/31/2010 4:20:53 AM •
Trendware...
Answered
on Oct 31, 2010
