Probably too late to help you, but the next person can benefit from this.
I soldered a jumper wire from the collector to emitter (outer two legs) on transistor Q1 on the back edge of the board near the top.
That keeps the voltage regulator on and the unit will transmit all the time instead of being shut off and on by the input sound level.
By the way, earlier my regulator went out so I used a beefy LM7812 to replace it.
My AC adapter also went bad, and it's a 24VDC type, so I used a larger supply form an old PC and put a toggle power switch on it.
You'll need to unplug the AC adapter form the wall or from the back of the unit to turn it off or install a switch somewhere.
We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
