20 Most Recent
Radio Shack CTR-121 Questions & Answers
I have the 43-127 recorder.
I have the same problem maria and I'm extremely upset. It doesn't work on my XP or my Win 7 machine and Radio Shack has NO support for the problem. I wish you luck.
Can't release tape from CTR-121
How much warranty you have left on that product. It sounds as if you need to get that replaced. Or You need a new button. something may be broken off inside the machine.
Optimus lab 1100. Huge distortion. I place my finger on the arm and all is good. Any idea ?
it is not a computer or PC so moved YAH/
it is home stereo sound turntable .from RADIO SHACK.
that that is easy seen it vast times back in the 60s.
- the pickup cartridge the needle there is packed in lint clean it .
- if not that , the tracking pressure is set wrong, RTM.
- if not that the tracking arm is binding find where and correct that.
- the needle is bad. (or its cartridge.
the manuals says, not adjustable, making this turntable junk class.
Ive owned many and this is junk.
that failures is pure mechanics, only.
here is mine, a real TT (note the brand)
https://imboldn.com/technics-sl-1200g-direct-drive-turntable/
note tracking controls full .
after a new cartridge upgrade that ways less it must be re calibrated for pressure and tracking. or fails.
PA Amplifier blows fuses
The fuse is blowing due to an overload. It's often and very likely caused by a transistor or ic that has gone short. The main culprits are the power transistors of the amp or whatever is on the big heat sink. Transistors will show the fault when you connect an ohmmeter to the terminals. It will be just like you have touched the test prods together! I don't think in your case it will be in the power supply. It's often caused by speaker cables that touch together.
What is impedance?
Check the impedance on the back of the speakers usually listed, and if you are lucky so is the power rating. The general rule is the amplifier should equal the power rating of the speakers for maxium performance or more. If you have a digital meter set it to ohms and measure impedance at the speaker input, if you have a model number do a general search to find out more additional imformation.
