20 Most Recent
Consew 7360R-1 Mechanical Sewing Machine Questions & Answers
Machine Locked
Hi, First of all, make certain you remove both parts of the needle. Sometimes it breaks under the plate and knots up with the bobbin. If that is so, lift the presser foot and carefully try to lift the plate so you can get scissors under it to cut the thread and free the needle. Pull the bobbin out and replace it and put a new needle in. It should work fine.
How to fix tension on 226r-2?
Contact manufacturer on line. They should be able to supply manual for you to use. These can usually be downloaded at no charge.
New Consew 146 rb 1-a Stitch length dial is set at
I would suggest taking the machine in to be adjusted and make sure they can work on that model machine, and if they can, then the same day you get it back, sew on it to make sure the problem is fixed.
My needle keeps hitting the
Your machine may be out of adjustment, here is the manual for your Machine http://consew.marginspluslive.com/images/products/pdf10/7360r-rh-rbboth.pdf -or possibly your needle is bent.
Consew Sewing Machine Manuals
Consew sewing Machine Manuals may be found at the link below:<br /><br /><a href="http://www.consew.com/default.aspx?pageId=4">http://www.consew.com/default.aspx?pageId=4
</a>
Stitch tension problem - bobbin
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Purchased in Nov 08 new.
Thank You for visiting fixya.com but you have not stated the problem you want to be solved. Please how can we help you?
