20 Most Recent Coolmax CD-350-COMBO (CD350COMBO) Infrared Adapter Questions & Answers
Does the Coolmax-350-Combo work with Microsoft
My approach is to put the old hard drive into the spare slot of the new computer. There should be an IDE cable plug somewhere. Makes things easy. I also use Clonezilla to transfer data.
4/8/2017 2:44:31 PM • Coolmax... • Answered on Apr 08, 2017
2answers
Cool max cd-350-combo does not
Don't know if you've solved this problem, but I was having the same issue using Windows 7, 64bit. It had been working but Explorer crashed & Explorer restarted, it recognized the device, but I couldn't access the files. I tried it on another laptop & it worked. So I left it plugged in & restarted the computer and that fixed the problem. If that doesn't work, you may have to uninstall the driver that windows automatically installed for it & then plug it back in & have windows reinstall the driver. Good luck.
1/7/2011 3:37:24 AM • Coolmax... • Answered on Jan 07, 2011
Won't acknowledge drive
Sounds like your leads test your IDE or SATA leads
7/25/2010 1:03:45 AM • Coolmax... • Answered on Jul 25, 2010
I have a dead hard drive 2.5" SATA
If it is truly dead and you MUST have the information from it then the only real alternative is to send it to a data recovery expert. These services are NOT cheap
If it clicks or makes random noises clicks pings etc then it is most likely dead I am afraid.
8/24/2009 7:03:05 PM • Coolmax... • Answered on Aug 24, 2009
Does anyone have the instructions for this as the
I would ignore the warning. I went to this web site. http://www.coolmax.com/ and my Web Of Trust gives it a questionable rating as there are not enough reviews to give it a good rating. I found nothing wrong with the web site. I suspect you may have spyware that has infected your computer. This is how they operate. They pop up scaring you and wanting you to click the scan or something else and when you do you have problems. Run all your security scans in Safe Mode and clean all the find.
8/5/2009 9:13:41 PM • Coolmax... • Answered on Aug 05, 2009
I bought an All-in-One Multifunctional
I have spent hours trying to figure out how this damn thing works since the instructions require the user to have way more computing skill than I. First, the thing comes apart, one part being the interface and additional power supply and the other being the power supply that may connect to the Coolmax or your HD power supply if not operational through the Coolmax. If your old HD is larger than 3.5", you may have to connect the power plug to the HD 4 pin power source. otherwise, connect old HD to the Coolmax CD 350 adapter and then connect the Support USB2.0 to a USB interface on your new computer. If your old HD is a 2.5 SATA , do not connect the red power plug to a USB2 interface on your new computer unless you are positive the old HD operates over 5V. Connecting the red USB power source to your new computers USB2 interface may cause the old HD to shoot sparks and smoke, and you will not need the device any more.
1/14/2009 5:07:01 PM • Coolmax... • Answered on Jan 14, 2009
2answers
My television will suddenly turn off every 4 minutes or so and when I turn it back on it will do it again. I need help to stop this please?
The most obvious reason is an overheating issue in the Power Supply board. There are other ideas here, but you need to take it to a television engineer to diagnose https://www.google.com/search?q=television+will+suddenly+turn+off+every+4+minutes ..
4/24/2024 6:22:38 AM • Televison &... • Answered Yesterday
Harwa Smart television. How to restore Apps, it doesn't want to open for Apps.
Check the internet connection. The television can't update if it can't see the internet. Resetting it breaks the previous settings. Just for fun, reboot the router as well and wait 15 minutes until all the lights come back on. Then reestablish the television connection to the router. Harwa is not a make we know here in North America. https://www.google.com/search?q=Harwa+Smart+television.+How+to+restore+Apps ..
4/23/2024 11:02:30 PM • Televison &... • Answered Yesterday
How to remove child lock from BELTEK TV?
general steps: Get the TV remote control and push the "Menu" button and select "Options". Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip". Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button. Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV. Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control. If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
4/22/2024 8:10:04 PM • Televison &... • Answered 2 days ago
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps: Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly. Switch on your TV: Ensure your TV is turned on. Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice. Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted. Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list. Bed.-Anl. H2 Version1 (ruwido.com)
4/21/2024 7:58:23 PM • Televison &... • Answered 3 days ago
My ecco TV is on but the screen is black when flashing light I can see the picture tv model LH 32.
That sounds like it has a backlight fault. A good TV engineer can possibly repair that for you.
4/21/2024 2:31:53 PM • Televison &... • Answered 3 days ago
Tek L26D10. How to open the unlock the TV unlock code for Tek model L26D10?
Ask your parents. There is no easy way to defeat the parental lock.. https://www.google.com/search?q=Tek+model+L26D10+TV+unlock+code ..
4/21/2024 5:35:32 AM • Televison &... • Answered on Apr 21, 2024
6answers
Vistron remote codes for sky
TV maker is Palladium codes are 0560, 398, 391, 446
4/20/2024 8:49:55 PM • Televison &... • Answered on Apr 20, 2024
JVC KW-AV50 DVD receiver. None of the volume Up or Down buttons work JVC KW-AV50.
Try cleaning behind them with electronics switch cleaner spray, but it may be the whole module is faulty. https://www.google.com/search?q=jvc+kw+av50+volume+button+not+working ..
4/20/2024 6:31:28 PM • Televison &... • Answered on Apr 20, 2024
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DIY or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered on Apr 19, 2024
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered on Apr 19, 2024
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered on Apr 19, 2024
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered on Apr 19, 2024
Coolmax CD-350-COMBO (CD350COMBO) Infrared Adapter Logo
8 questions posted
Top Coolmax Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Coolmax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Coolmax Televison & Video
Most Popular Question
cool max cd 350 combo not
  • Televison & Video
