20 Most Recent
Snom 300 IP Phone Questions & Answers
How to fix snom 300 because it cannot received calls
Is your phone connecting to a hosted PBX provider or is it connecting to a premise-based IP PBX? Incoming and outgoing calls are usually handled by two separate connections between your PBX and the service provider SIP trunk. Sounds like a registration problem with the SIP trunk. There is nothing you can do from the phone itself to fix this.
Snom 300
this is not a solution - we have the same problem too.
have about 70 snoms here and sometimes the display shows only black
boxes. a reboot helps then mostly for a while.
telephones are connected by poe or voltage adapter.
never had over voltage and i can't remember on power outages.
My snom 300 phone displays
try resetting the vlan settings if that doesnt work ensure that the default gateway and dns settings are correct.
HOW DO I UNLOCK MY
To lock or unlock a Snom 300 keypad you will
use the * key. Hold this down until the lock icon appears and hold down
again until lock icon is gone to unlock.
I have NR
nr is an abreviation of no route check the ip address, subnet mask and the default gateway, ensuring that you dns server is set to your default gateway also, i have the same problem with a customer in spain.
