20 Most Recent
Intel P4 System Configurator (P4SDRAM1) PC Desktop Questions & Answers
When i power on the
when PC cannot boot there is probably failure on installation RAM, VGA (external), or Power Supply. in your case (no beep) maybe it is your power supply don't have enough power to boot or its already damaged. try to another power supply with higher voltage (watt), or change with the new ones. hope this useful, regard riyan.
Intel base-code,PXE-2.5 (build 083)
Go into the BIOS or System Setup and make sure you have it set to boot from your Hard Drive first. This might be trying to boot from a LAN.Turn your computer off, then turn it on and watch for which key to hit to get into the Bios or System Setup.
I want to install sound system my system
Do you need just to install the speakers or the sound drivers? What is your exact problem? Also clarify me what is your motherboar's brand / model.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
I need lan card driver installer for my intel mc
Hello marla lakip,
Please visit the manufacturers support website and find your specific model number. They should have all the drivers you need. If you still have problems, please reply with the Make and Model of your PC and we will try and help you the best that we can.
Audio losse
hablas espanol dime cual es el problema verifica los driver de la maquina para audio , verifica cableria , verificA las bocinas
Sim
there is a problem with the memory sticks.
My cpu intel p4 lost sound driver
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
Windows 98Gold/98se/Me/2000/XP/2003(32/64 bits) for Driver only. For Windows 98 SE, DirectX(R)8 is required to enable advanced features. (Executable file)
most likely this is the driver you need, hope it works
Reagarding some Hard disk
You system probably supports IDE hard disks up to 200GB in size. It all depends on what chipset was used on your motherboard. Since it is a PIII system, the 200GB limit is most likely quite solid. Although, you can get past this by installing a PCI card that can handle larger capacity drives. You could also opt for using a SATA controller, but you will be limited to SATA-150 instead of the more current SATA-300 with a PCI interface.
Windows XP installing problem
Your harddisk has some bed sectors.
U have to go to delete all partrition then turn off the computer then again boot withwinxp disk
then create new partrtion then format ntfs quick
then it error not comes.
No sound
The problem may be caused because the driver file may be damages due to some reason. To get the sound back you need to run the motherboard cd and install the sound drivers "realtek".
or
you can download them online:-
just enter the name of your motherboard and "sound drivers"
Sound
Sir i have not heard any sound on my computer. my computer's motherboard name is PRESCOTT S33 and the number is (fw82801 eb),(f332nc51),(3l7gz),(Intel mc 02) which one of these no. of my board no. i do not know. but i still sure that u solve my problem earliar.
thanking u
