20 Most Recent Hobart HL200C Mixer Questions & Answers
3answers
Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
5/15/2018 6:57:44 PM • Hobart HL200C... • Answered on May 15, 2018
3answers
MY Hobart Hl200 is working
hello! the speed select switch is defective...It is located behind the timer control board...Part # is...00-874831
Guru.............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
4/1/2011 1:44:16 PM • Hobart HL200C... • Answered on Apr 01, 2011
I need a wiring schematic for a Hobart A-200T
Here is the complete manual of parts with exploded views and part numbers:
http://www.wasserstrom.com/wcsstore/ExtendedSitesCatalogAssetStore/Attachment/item%20680610.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
12/5/2010 6:20:04 AM • Hobart HL200C... • Answered on Dec 05, 2010
I have a Hobart Mixer Hl200 that used to work with
It is difficult to determine the exact cause of the problem but it most certainly lies in the speed selector switch itself. The switch is a rotary mechanical switch which can only take so much wear and tear.
You can view your mixer online at:
http://www.hobartcorp.com/products/food-prep/mixers/legacy-countertop-mixer/
There are contact numbers and a dealer directory on the web page to direct you to your nearest stockist of Hobart parts and accessories.
Best wishes,
Graemevm
3/16/2010 7:52:58 PM • Hobart HL200C... • Answered on Mar 16, 2010
Hobart 20qt just will hum motor wont take off .
Motor start capacitor failed or start run switch mounted at back of motor housing damaged
11/13/2009 8:37:14 AM • Hobart HL200C... • Answered on Nov 13, 2009
HOBART HL200 error code oc3.
For $9.95....I'll tell you
12/11/2008 5:41:56 PM • Hobart HL200C... • Answered on Dec 11, 2008
How to take apart Hobart A200 shifter/speed unit.
Here is the Technical Manual https://www.partstown.com/modelManual/HOB-A200_spm.pdf Repair help and videos. https://www.google.com/search?q=hobart+a200+repair
Hobart A200 Restoration
The Fresh Loaf https://www.thefreshloaf.com > node > a200-restoration Mar 8, 2020 - I'm currently disassembling my A200 and I can't seem to get the planetary to just slide off like the videos seem to show. Am I missing something ...
My Hobart A200 rebuild
The Fresh Loaf https://www.thefreshloaf.com > node > my-hobart-a200-... Oct 21, 2021 - So I took it completely apart, cleaned and degreased it inside and out, stripped the old paint, replaced the worn parts (power cable, bearings ... ..
3/1/2024 12:31:09 AM • Hobart Food... • Answered on Mar 01, 2024
For Hobart A200 the capacitor is starting or running capacitor?
It is a Start Capacitor. It give the motor a jolt to get it running.
HOBART, Fits Hobart Brand, For A120/A200, Capacitor ...
Grainger https://www.grainger.com > product > HOBART-Capa... HOBART Capacitor, Motor Start: Fits Hobart Brand, For A120/A200 ; Item: 235F28 ; Mfr. Model: 00-070487-00025 ; Catalog Page: N/A. US$41.13
MOTOR STARTING CAPACITOR FOR HOBAR MIXER ...
eBay https://www.ebay.ca > ... > Commercial Mixers MOTOR STARTING CAPACITOR FOR HOBAR MIXER MODEL A200 REPLACES 7048700018 ; Condition. New ; Quantity. 67 sold. 82 available ; Item Number. 254321066847 ; Brand. Rating: 5 · ‎ 1 vote
Motor Starting Capacitor Fitting Hobart Mixers A120, A200 ...
National Band Saw Parts https://nbsparts.com > All Products MOTOR STARTING CAPACITOR FOR HOBAR MIXER MODEL A200 REPLACES 00-070487-00018. 125V, 50/60HZ, 145-174uF. Includes: One Capacitor. Replaces#: 00-070487-00018 ... US$30.00 · ‎ In stock https://www.google.com/search?q=Hobart+A200+the+capacitor+is+starting+or+running+capacitor ..
2/7/2024 4:24:15 AM • Hobart Food... • Answered on Feb 07, 2024
My Hobart A200 lift arm seems frozen. Sat in garage covered.....won’t lift.
There are a few retaining screws in the guide's that you can undo to clean the runners. They get gummed up with flour over time. This should help
12/3/2023 4:50:52 PM • Hobart Food... • Answered on Dec 03, 2023
Hobart Legacy Mixer error ER1. Que significa?
Question edited to a lot more clarity. Question translated to English. We are a North American site. https://translate.google.ca/ No model given, 'Legacy' is a range of mixers. 'Er1' is a memory error. Page 3 refers. https://manualzz.com/doc/4212431/hobart-hl200-error-codes-and-trouble-shooting https://www.google.com/search?q=Hobart+legacy+ER1 ..
10/31/2023 3:14:39 PM • Hobart Food... • Answered on Oct 31, 2023
Hobart A200 mixer won't start no power, any suggestions of next steps?
My experience with electrics has mostly been coffee grinders, hand held food blenders and vacuum cleaners but these are the checks I do. Sadly you'll have to open her up again to do these. Personally I wouldn't use compressed air. Some compressor pressures can be a bit too powerful. I would suggest a vacuum. Stick the foot end of a pair of tights (pantyhose) over the nozzle that way you get suction but you don't lose nuts and screws up into the vacuum. Opening her up again might reveal a loose wire you missed rebuilding it. That was my issue with a vacuum cleaner I rebuilt. -Turn the motor by hand using the shaft the blade bolts to. Your feeling for it smoothly and quietly turning. If it's gritty, noisy or your getting tight spots there's dirt or something inside or a bearing is worn out. -Test for voltage at every point where a wire ends and connects to something else like switches, circuit boards and the motor itself. -Disconnect the wires to the motor and test for Continuity. Set your Multi meter to Ohms (the little horse shoe symbol) and touch the test probes, one each motor terminal. You should get a very low number somewhere near zero. Most multimeters will beep when you have continuity. If you get an 'L' or 'OL' there's a short or a broken wire. -I would then do the same test across all the switches on the machine, wires off and test the switch. Just because they move doesn't mean they're working. These steps usually work for me so give them a try, the multimeter won't hurt the machine.
10/7/2023 4:36:18 PM • Hobart Food... • Answered on Oct 07, 2023
Besides oil in gear case do i need to grease and other parts on a 4822 hobart grinder
Your'e good to go...Tip...keep the meat in a freezer for 30 minutes before grinding it. Apply olive oil in the interior parts of the unit to reduce the friction.
2/28/2023 5:56:19 PM • Hobart Food... • Answered on Feb 28, 2023
Hobart A200 transmission, marble sounds, resistance with shaft support installed
It sounds like there may be a few potential issues that could be causing the resistance you are experiencing:
  1. Incorrect installation of the slow speed gear or key - If the slow speed gear or key were installed incorrectly, this could cause increased resistance in certain gears. Double-check the installation of these components to ensure they are properly oriented and positioned.
  2. Stuck gears - If the gears and key are stuck on the drive shaft, this could cause increased resistance. Try removing the gears and key again, and make sure they are clean and free of any debris before re-installing them.
  3. Improper alignment of the gears - If the gears are not properly aligned, this could cause increased resistance. Check to make sure the gears are properly seated and aligned with each other.
  4. Damage to the worm wheel - The freshly chewed up center of the worm wheel could be causing increased resistance. Consider replacing the worm wheel if it appears to be damaged.
Overall, it may be helpful to consult the Hobart service manual for your specific model to ensure all components are installed correctly and to troubleshoot any additional issues that may be causing the resistance.
2/26/2023 5:18:15 AM • Hobart Food... • Answered on Feb 26, 2023
Hobart Legacy HL200 stopped working?
That is a $10k to $20k mixer, depending on where you buy it. I have used one of these. Unfortunately, grinding noises that result in the motor stopping can be fixed with a power disconnect. Grinding noises = dry bearings, to seized bearings, to shredded or stripped gears. You need a Hobart Service Tech. https://www.google.com/search?q=Hobart+Legacy+HL200 ..
1/20/2023 9:46:40 PM • Hobart Food... • Answered on Jan 20, 2023
2answers
I have 2 Hobart A200 mixers, and they need to be refurbished. Any idea how much that would cost?
I'd give them a call they would be the best to get a more detailed estamate from. https://www.hobartcorp.com/locations?s=342
1/20/2023 9:36:03 PM • Hobart Food... • Answered on Jan 20, 2023
Proper installation of Hobart A200 oil seal
Watch the videos and see if you did it correctly. The oil seal is tight in its seat so it can't be off centre. The best thing for bedding seals is a hydraulic press and a large socket. https://www.google.com/search?q=installation+of+Hobart+A200+oil+seal ..
12/22/2022 2:23:57 AM • Hobart Food... • Answered on Dec 22, 2022
Hobart HL200C Mixer Logo
9 questions posted
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Hobart Food Mixers
  • Hobart Food Mixers
Most Popular Question
need oil grease hobart 20 qt mixer
  • Food Mixers
